Question about Ricoh Aficio Office Equipment & Supplies
Ricoh CL2000, How do I enter service mode, and reset (CMY page counters)?
Have entered service mode to (CMY counters) but can not properly execute counter reset to zero.
Posted by mackattk on
paulfvincent
    Champion:
  • Ricoh Expert
  • 208 Answers
What are you trying to do? Some counters do not reset. Only those for consumable items can be reset.
Posted on Feb 03, 2015
5 Related Answers
Anonymous
  • 76 Answers
SOURCE: how to RESET counter
Of course, the printer settings can be changed via the standard print options menu in Windows but to reset the counter is done when a new cartridge is installed. But this is how I would proceed... Since the printer and the cartridge are in "cahoots", I'd not give them the chance to communicate. Do this: Place some tape over the electronic contacts on the cartridge. (This prevents the printer and cartridge communicating) Then... Setup another printer icon using the HP Laserjet 4 (MS) printer driver. (This ensures no communication between the installed software and the printer). This should allow you to print some more, but not duplex of course. Remember to shake the cartridge from side to side in order to loosen impacted toner. ZT3000 "Beta tester of "0"s and "1's
Posted on Aug 19, 2007
Anonymous
  • 37 Answers
SOURCE: The PCU Reset procedure needed
switch the machine off at the switch hold down online and escape while switching on the switch , hold the buttons till you see service mode on screen , you need to go to engine , then drum , there you will find the setting to reset the pcu , or under data log is a function pm counter clear if it is giving you replace pcu on the screen
Posted on Nov 16, 2007
Anonymous
  • 41 Answers
SOURCE: how to reset wasted ink counter
Mp150
Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Posted on Feb 11, 2008
olayoju victor
  • 191 Answers
SOURCE: how to get into the service mode
press button C & 8 at the same time to show u the error no. its the error no that will let u know the fault type.
Posted on Sep 29, 2008
pineworks
Clive
  • 4345 Answers
SOURCE: Can't get past step 2 of the Canon i550 waste tank counter reset.
Hello you can try
Problem for Canon BubbleJet i560 InkJet
The waste ink is in the inside of your printer you need to get at it to clean out,
It may be all screwed down so you need to open all up or get a shop to do it for you.
It not an easy job but maybe you are handy with a screwdriver, it can be messy job.
But after this, you will have to reset the waist ink counter or it will still not work,
But but but but you can always try this to reset it first and clean it out again some time.
Canon Reset waste ink counter
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
How to reset Toshiba Studio 256se Total Counter?
Clearing counter
The counter indicating "current number of prints and driving time" used for the PM display function is
reset by entering "0" in it or clearing it in the PM support mode.
Notes:
Even if "0" is entered in the PM management setting value of the setting mode (08), the
corresponding counter for the PM display is not reset. Be sure to clear the counter in the PM
support mode when the maintenance is finished.
The reset condition of each counter is as follows:
• 08-6194: Current value of PM counter [process unit (K)]
• 08-6195: Current value of PM time counter [process unit (K)]
When the current value of "CLEANER/DRUM" on the main screen or "DRUM" on the sub-screen in
the PM support mode is cleared, the counter is reset.
• 08-5568: Current value of PM time counter [developer material (K)]
• 08-5569: Current value of PM time counter [developer material (K)]
When the current value of "DEVELOPER" on the main screen or "DEVELOPER" on the sub-screen
in the PM support mode is cleared, the counter is reset.
• 08-5576: Current value of PM counter [parts other than the PM parts of the process unit]
• 08-5577: Current value of PM time counter [parts other than the PM parts of the process unit]
• 08-6225: Number of output pages (Thick paper 1)
• 08-6226: Number of output pages (Thick paper 2)
• 08-6227: Number of output pages (Thick paper 3)
• 08-6228: Number of output pages (OHP film)
• 08-6244: Counter for tab paper
• 08-6247: Counter for envelope
When the current value of "FUSER" on the main screen or "FUSER ROLLER" on the sub screen in
Notes:
The following counters are cleared by executing the EPU replacement mode.
08-5568: Current value of PM counter [developer material (K)]
Jun 14, 2016 | Toshiba Office Equipment & Supplies
Tip
Reset Waste Ink Absorber Canon i550
The following procedure is used to reset waste ink counter Canon i550.
PROCEDURE:
I. Enter Service Mode:
  • Plug in power cable
  • Hold down RESUME/CANCEL button
  • Hold down POWER button
  • Release RESUME/CANCEL button
  • Press RESUME/CANCEL twice in a row
II. Execute Waste Ink Counter Reset operation:
  • Press RESUME/CANCEL button 4 times in a row
  • Turn off the printer by pressing POWER button
on Jan 03, 2010 | Office Equipment & Supplies
How do one enter to Service Mode level 3 of Canon irc3200
That level 3 mode is only for Canon engineers. What counter are you looking to reset? The counters for most maintenance items are reset in service mode level 1. The total counter for the machine cannot be reset without replacing the main controller pcb & the counter pcb.
Jul 25, 2012 | Office Equipment & Supplies
Canon MP130 - warning keeps coming up that the 'waste ink absorber is nearly full. What do I need to do to correct this, thanks for your help.
Hi Teasel850,
There is an internal counter that prompts this message. There is software to reset the counter called MPTool. But why complicate things when it can be reset manually using the following steps.
Reset Canon Pixma MP130 Printer
  1. Turn on the printer.
  2. Press the MENU key, and then SCAN, COPY and SCAN again - entered the service mode.
  3. Select NVRAM ACCESS further OK.
  4. Select SET ABS-M LEVEL and set value equal to zero.
  5. Select SET ABS-R LEVEL (if any) and is set to zero.
  6. Turn off the printer POWER button.
Best regards
Mike
Jan 30, 2011 | Canon PIXMA MP130 All-In-One InkJet...
How to reset SHARP AR5320e counter reset back to zero thanks...
hello i think sharp 5316/5320 their have no feature to reset counter
but try this code some time it help you press # ,intrupt button ,C ,intrupt button then you enter to service mode then,
press 24 press start button then press 8 start key then copy coun value is reset to zero and displayed on the 7-seg.then press intrupt key the machine goes to sub code input standby mode.pressed CA key simulation is terminated.
Jan 18, 2011 | Office Equipment & Supplies
Error code E000013-0001
getfile.asp?rid=1258 February 2, 2005 getfile.asp?rid=3215 Product : imageRUNNER C5800 / C6800 Title : E013 code and Waste Toner Full message Question :
The copier shows an E013-0001 and "Waste Toner Full" message. The Waste Toner Bottle has been emptied and SW1 is operating properly but the code and the message are still appearing on the display.
Answer :
The counter for the Waste Toner Bottle needs to be reset back to zero in Service Mode.
Enter Service Mode level 1 by pressing * 2 8 *, select Copier > Counters > MISC, then highlight WST-TNR, press Clear - the counter will zero out.
Power off the copier, turn the copier back on, the Waste Toner Full message on the display should clear out.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
Ink absorber nearly full. what is the solution
open absorber and keep outside from printer and clean in water properly
May 08, 2010 | Canon PIXMA MP130 All-In-One InkJet...
The waste ink absorber is almost full How do I fix it Please?
It needs to go to a shop to have the absorber changed and the counter reset. Only a Canon shop has access to parts and service mode to reset the ink counter.
Dec 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
PRINTER PixmaMP 130
HI
You can try.
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
  1. You will include printer.
  2. press button MENU, then SCAN, COPY and again SCAN - they entered into the service regime.
  3. select NVRAM ACCESS and further BY OK.
  4. select SET Abs- m level and advance value equal to zero.
  5. select SET Abs- r level (if there is) and also you will establish into zero.
  6. you will turn off printer by button POWER.
All best
Waste ink absorber nearly full. Canon pixma mp130/110. How do I empty it?
Canon MP110, MP130
1. Include the printer.
2. Press the button "Menu" , then "Scan" , "Copy" and once again "Scan" (all - fell into service mode).
3. The Arrow to choose "Counter access" , press "OK" .
4. The Arrow to choose "ABC-M DOT Count" (or "ABC-P DOT Count" - depends on that, evidences what from counter = 100 ) and press "Copy" .
5. The Button "-" throw the counter before "0" , and press "OK" .
6. For leaving from service mode to press "Resume" .Good luck! Cheat that you dispose of problems!
Sep 28, 2009 | Canon PIXMA MP130 All-In-One InkJet...
596 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
