Anytime I get into an unfamiliar saw I always take a number of pictures with the I-phone to help with reassembly. Not too much help is it?
It will only go together correctly ONE way. Do not force any of the parts as if you bend the carb linkage, you will forever have a problem with it. A hint: sometimes the parts have to be inverted and slowly twisted or turned back upright to install.
SOURCE: I just took apart the brake mechanism on my poulin
The only known illustration for a Poulan 2375LE is here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
It appears they want you to purchase the entire clutch cover. There is no specific detail.
Type 1 pn530054740 item 39 $19.43
Type 2 pn545139903 item 36 $19.43
There are other than 2375 Wild Things.
Go here for additional help identifying your saw. Please have it within easy reach if telephoning.
http://www.ordertree.com/cms/Contact+Us/6.html
HTH
Lou
SOURCE: I can not reassemble carb cable/trigger mechanism
heres the parts ipl should help
http://www.poulanpro.com/ddoc/POUI/POUI2008_AAaa/POUI2008_AAaa_PP4620AVX_952802146.pdf
