Question about Moultrie M-990i Game Spy No Glow Infrared Digital Trail Camera - 10MP
The main screen has write protect on it and it wont allow it take any pictures
Ive taken the memory card and and switched it to the unlocked position and put it back in but it still says that
Posted by ryan leitow on
Chris Hunt
    Genius:
  • 1,342 Answers
Try another brand of memory card.
Posted on Jan 17, 2015
I have a mesasge that says 'write protect' which stops me from taking any pictures. I can view photo's already taken, but can't delete any. I'm not sure how or why (could of been the kids...) this...
You didn't specify the make and model of your camera, so I'm assuming it uses SD cards.
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Mar 10, 2011 | Cameras
How do i unlock the sd card in my s600?
Remove the card from the camera. The is a little switch on the left side. Slide it up. Put the card back in. Should be unlocked.
Mar 05, 2011 | Samsung Digimax S600 Digital Camera
Samsung sl600 is saying card locked when I try to take a picture
Remove the memory card from the camera, along one edge you will see a tiny switch, slide it towards the contacts to unlock the card, the switch that is in the farthest position from the contacts is in the locked position to prevent deletion. Now! if the card is in the unlocked position slide the switch back and forth to reset the card. If that fails the card should be replaced.
Mar 03, 2011 | Samsung SL600 Digital Camera
Ive just bought my camera, ive installed it etc, when i take a picture " card protected " shows, and therefore no pictures save, helpp!!
You didn't specify what make and model camera you have, so I'm going to assume it uses SD and/or SDHC cards.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 16, 2010 | Cameras
I have a Casio Exilim EX-S10. When I turn it on it says ''The card is locked''. I've taken the memory card and battery out, put it back w/no change. When I put the memory card in the computer it doesnt...
Mar 15, 2010 | Casio Cameras
Says this memory card is protected - can't take
Kindly follow the steps below
Remove the memory card from the camera.
Look at the memory card very well, you will see a slide switch on the side edge of the memory.
Move the switch to the unlock position.
Put the memory card back to the camera.
You can then start using it.
Thanks
Oct 16, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Says memory card is protected
Jun 15, 2009 | Kodak EasyShare Z1015 IS Digital Camera
I835 keeps saying card protected won't show pic taken
SD cards have a little slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Apr 01, 2009 | Polaroid i835 Digital Camera
How to unprotect the memory card
Memory card has a slider switch which prevents write access. Move switch to other position.
May 15, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Moultrie M-990i Game Spy No Glow Infrared Digital Trail Camera - 10MP Logo
1,259 people viewed this question
Top Moultrie Video Cameras Experts
Harrie
Andrew Taylor
Andrew Taylor
Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
