Question about Amazon Kindle Fire HD
How do I unlock kindle fire that has fbi scam virus?
Posted by danielle combs on
Mikey
  • Amazon Master
  • 6,306 Answers
Factory reset! Turn off, press power and volume+ buttons together, on reset page select factory reset!
Posted on Jan 17, 2015
  • 1 more comment
  • danielle combs
    danielle combs Jan 17, 2015
    I shut it off but when i push the two buttons you say it takes me to my home screen then right back to the scam page. I cant access settings or anything.
  •  Mikey
    Mikey Jan 17, 2015
    Ok! Try pressing power for about 30 seconds after this the kindle should be off, then repeat the above procedure.
  • Dane Jones
    Dane Jones Dec 19, 2018
    Yeah I tried that it doesn't work
I bought an amazon Kindle Fire on ebay and cannot get it unlocked. help please.
Brenda, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Reset Locked Kindle Fire
Kindle Fire HD how to reset when locked up EpicReviewsTech CC
when ur locked out of ur kindle how do reset it
Kindle Fire Password Remove
Mar 02, 2016 | Amazon Kindle Fire HDX 7
Fix virus on kindle fire
Contact amazon.com, click Your Account, on left side find kindle Help Home, next page on right click CONTACT US. fill out info and they will respond.
Jan 27, 2016 | Amazon Kindle Fire HD
When screen opens it suddenly starts asking for a password. I have never used a password, don't have one and cannot unlock my Kindle Fire HD
Give enter to password, in blank, withoul inputting anything. Maybe it accepts it as password.
The other possiblity is that you've been pranked and someone defined a password
Here you have a tutorial for Password Remove:
If you can't get the password, you should do a Factory Reset.
Here you have some video tutorials how to do
Kindle Fire HD How to Reset Back to Factory Settings
How to Factory Reset Amazon Kindle Fire Tablet Tutorial
Jul 08, 2015 | Amazon Kindle Fire HD
How to unlock kindle fire
Forgot my password
Did you forget the password used to unlock your Kindle? If so, you'll need to reset the device to gain access. By resetting, your Kindle will be restored to factory defaults, which means your registration information and content will be removed, and all settings will return to the defaults.
To reset a Kindle Fire 1st Generation:
1. From the lock screen, slide the Unlock Bar from right to left
2. Use the keypad to enter characters into the password/PIN field four times
3. You'll be prompted to reset your Kindle Fire. Tap "Ok reset"
To reset all other Kindle Fire models:
2. Use the keypad to enter characters into the password/PIN field five times.
3. When prompted to reset your Kindle Fire, tap "Reset"
To reset a Kindle 2nd Generation, Kindle Keyboard, or Kindle DX:
1. Slide and release the power switch to turn on the device or exit sleep mode
2. Enter "resetmykindle" in the password field and press the enter key on the key pad
3. Wait several minutes while your Kindle restarts
To reset a Kindle (5-way controller):
1. Press and release the power button to turn on the device or exit sleep mode
2. Select the keyboard key once on the password screen and enter "resetmykindle" in the password field, then select "Enter"
To reset a Kindle Touch or Kindle Paperwhite:
2. Tap the password field to bring up the onscreen keyboard
3. Enter "111222777" and select "OK"
If you don't remember your Parental Controls password, you can deregister your device instead of resetting, as long as you're connected to a wireless network. You'll need to redownload your content, but items that were transferred via USB will be kept. Here's what to do:
1. Visit the Manage Your Content and Devices (www.amazon.com/manageyourkindle) page on your computer
2. Select the "Manage Your Devices" link
3. Select "Deregister" to deregister your device from your account
Sync your Kindle, then register again.
If you need help with your Wi-Fi password, please contact your Internet Service Provider or router manufacturer.
Feb 25, 2015 | Amazon Kindle Fire HD 8.9"
Pass word pop up on kindle fire after update
This was a software update problem Call customer service at 866-216-1072.
Feb 24, 2015 | Amazon Kindle Fire HD
Http//www techinipages.com/Kindle_fire_how_too_uninstall_apps is not available it says it's not available what do I do now?
IMHO the kindle fire is a scam, its amazons control of what you buy etc
go to your cloud & remove them there
Feb 07, 2015 | Tablets & eReaders
Unlock kindle fire pin code
Once the Kindle Fire is locked, there is no override or back door to unlock the device. You will need to contact Amazon to unlock the device. They usually send you a new device.
Apr 21, 2013 | Amazon Kindle Fire HD
My kindle fire hd is locked.
If you see a lock when you open the kindle have you tried to run your finger from the lock across the screen??? Most new kindle users are unaware of this as I was. If that isn't your problem then I cannot help you. good luck.
Dec 18, 2012 | Amazon Kindle Fire HD
Amazon Kindle Fire HD Logo
591 people viewed this question
Top Amazon Tablets & eReaders Experts
Poul Brinchs Larsen
Pierre Legault
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
