Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
My Indesit d41 dishwasher does not release the lid to allow the tablet to drop into washer. can you help me please?
Posted by Iain Leitch on
  • NiteFalll Jan 17, 2015
    Hi Iain Leitch, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? So to make sure I understand, the lid never comes open even after it cycles through?
5 Related Answers
Anonymous
  • 236 Answers
SOURCE: Dishwasher tablet not releasing
sounds like the dispenser solenoid is faulty you will need to replace the whole unit, this involves removing the door panel.
Posted on Jun 11, 2007
Anonymous
  • 159 Answers
SOURCE: Indesit D41 dishwasher problem
you need to check the inlet walve . when you start the unit you say it drains. so after the drain do you hear the water entering the dishwasher? If you hear a sound like a buzzing noise that would be the inlet valve working. if thats the case there is a clog at the screen in the valve not allowing the water or enough water in the tub. seeing that this is a portable unit you will also want to check to make sure the fill hose is not kinked up anywhere in the cabinet or under neath the dishwasher. If you hear no buzzing noise you need to check the inlet valve with a meter to first make sure your getting power to it and that the valve itself if good. check these things out and let me know what you found and we can go from there
Posted on Aug 06, 2007
Anonymous
  • 209 Answers
SOURCE: indesit d41 dishwasher
try testing the door interlock, actually this is only a micro switch inside the door behind the plastic front panel, there could also be the possibility there is a broken wire behind the door skin just above the hinge part, take care when working on appliances do not force parts to remove them and always unplug at the mains hope i have helped, if so please rate me well
Posted on Sep 26, 2007
Danny
  • 160 Answers
SOURCE: indesit d41 dishwasher overfilling, pressure
possible faulty pressure switch or a faulty drain pump
Posted on Dec 21, 2009
Testimonial: "cheers"
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: indesit 18
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
,.gf.lo
Posted on Sep 29, 2010
Indesit 18" d41 dishwasher leaking from bottom of door area
Leaking Dishwasher
heatman101
,.gf.lo
Jan 23, 2010 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit D41 dishwasher, switch it on to program,
if applaince does not start draining then there is a possible fault with the door locking assembly,and the appliance thinks the door is open and this will not allow the appliance to start
Jun 28, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
Nov 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Door won't shut
Is there sufficient spring reaction? Spring weak or broken? Has latch or catch moved? Is there adjustment on either? Is there debris stopping mechanism from working? Has door dropped?
May 11, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit D41 Slimline
HI THERE - I ALSO INHERITED A D41 - I HAVE JUST FOUND - SITE WHERE YOU CAN DOWN LOAD INSTRUCTION MANUAL FOR MANY INDESIT PRODUCTS - I NOW HAVE INSTRUCTION MANUAL FOR MY D41 NICELY PRINTED OUT - SEE www.indesitservice.co.uk hope this helps you too - Helen
Nov 14, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Appliance runs through complete cycle without heat or tablet release
if the element looks fine it still could have gone faulty inside,test this with a multimeter for being open circuit, there are also thermal cut outs to test, these can also cause the machine not to warm up, you cant tell by looking sorry the tablet box may not release because with no heat the programme will not advance to that part
Sep 27, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Sep 26, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwasher
I don't understand if you already solved your problem or you still looking for an help.
Aug 19, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Jun 08, 2007 | Indesit 24 in. DE73 Evolution...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
Top Indesit Dishwashers Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
