It could be the temp sensor going bad. This sensor sits on top of the
metal housing which the bulb assembly slides into. The bulb assembly
will have a hole on top and this is where the sensor is above. There is a
small blue and white wire that plugs into it. If you pull the wire out
and put a paper clip or wire in the coupling you will basically bypass
the sensor connecting the blue and white wire. If your tv turns on then
that is your problem. Its cheap too. Here were my symptoms..1] Turn tv
on 2] Bulb would light up..(which eliminates the ballast) regular
picture would show up (which eliminates the bulb and color wheel) 3] 30
seconds later tv would shut down with 3 flashing lights. After bypass
the tv turned on as always and hasnt shut down yet. Always un plug tv
first. Get the replacement part to avoid overheating and possible fire
If you do not hear the color wheel start to spin inside of light engine this may have failed also check to make sure fans are working and safety switch is making contact
The first place to start is with the Main bd. The second cause would be the T-con bd. Have a trained Samsung tech troubleshoot to find out and repair the set.
are you a technician if so go to the relay circuit and fix that circuit more than likely has bad ic like the eprom . are leaky transistor also check the power button for lose connection they are tiny little switches now a day
