Televison & Video Logo
r
raymond fox Posted on Jan 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have sound but no picture any answers
Turned the tv on and off tried most things
John Ray
Level 3:
  • Master 790 Answers
  • Posted on Jan 17, 2015
John Ray
Master
Level 3:
Answers
790
Questions
0
Helped
186515
Points
2180
Without knowing the correct model number, it would be hard if not impossible to relay an answer.
Testimonial: "samsung DNie DV3"
2 Related Answers
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jun 26, 2010
SOURCE: we were watching tv and tv popped. picture went
No backlight can be caused by the 24vdc power supply failure that feed the backlight inverter boards, or the backlight inverter board went out, or the logic board is not sending the turn on signal to the 24vdc power supply and the inverter board, that is what we need to find out first before jumping the conclusion and buying the wrong parts. Logical steps are needed to do any troubleshooting so we are not making guess buy throwing parts at the problem until the problem is solved, it gets expensive.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Anonymous
  • 586 Answers
  • Posted on Sep 02, 2011
SOURCE: I have a hct hpp
Hello there,
My dear friend, this televisions come up with funny problems and leaves people pondering what the cause could be and if it could be fixed. Changing the cables definitely is not the solution as the problem wan from inside of the unit.
Yes The problem can be fixed and No, you do not need to buy a new television.
The problem simply is related to what brings display to the screen. When you are having a picture that flutters. It simply is that the convergence board of the television is burnt out and need to be replaced. You also need to have the t-con board of the television checked along side the lamp. Once you have checked them, you will be able to tell the component that need to be replaced as these are the components related to the display on the screen.
Have a technician run a check on these components (the t-con board, the convergence board and the lamp) Also have him check all the capacitors on all the boards of the television as that could suprisingly be a cause of the problem.
Hope this information helped you my dear friend. As it would have been much easier if one was working on the television so as to be able to tell the precise part to replace.
Hope this information was helpful to you seahawkck Goodluck Elect_Comp
2answers
Cannot get any sound from JVC television model LT-22c540
Could be a problem in the motherboard make sure you check for recalls but first check to make sure that all your programmed settings are correct with your remote through menu
There is no sound from the tv, how do I turn on sound?
About 243,000,000 results (0.42 seconds) Search Results
    10 Ways To Fix A TV That Has A Picture But No Sound ...
    removeandreplace.com/2013/11/14/10-ways-fix-tv-picture-sound/
    Nov 14, 2013 - If your TV has a picture but no sound coming out of the speakers, thereare a few things you can easily check. ... See below for the best solutions to fix a TVwith no sound. ... Television Has No Sound Answer 1: Make sure TV is not muted.
    There is no sound or low volume coming from the TV ...
    https://us.en.kb.sony.com/.../there-is-no-sound-or-low-volume-coming-f...
    Aug 15, 2015 - There is no sound or low volume coming from the TV speakers. Article ID: ... Make sure no headphones are connected to the TV. Verify that the ...
    Picture But No Sound TV - Bright House Networks Support
    support.brighthouse.com/.../Picture-But-No-Soun...
    Bright House NetworksIf you have picture but no sound. Press to ... Ensure that the audio and video cables are connected to the same inputs on the TV. For example, if ... My BHN App.
    No sound from my TV via HDMI when my cable box is ...
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
2answers
How do I repair our Samsung LCD Television? I would really appreciate an answer ASAP. Where will my answer appear for my review.
Don't know what service provider you have, free to air, satellite, cable or what? Try feeding the TV another signal and see what it does. Play recorder movie from DVD, or if you have a VCR around even try that. If it plays the DVD etc, with no issues, then TV is not the problem, most likely the cable box, satellite box etc, could be as simple as a bad cable connection at the house, a splitter or street box. Eliminate all the simple things first, then look at the TV.
Tv powers up to green,but just lights up dark blue screen,nopicture,sound,etc.
I just answered that a while ago, why do you people ask the same thing several times?
No picture but sound. When turning the tv on the
Power supply issues - I bet bad capacitors 'dried out' .
A good servicer should be able to fix it for you.
NO PICTURE OR SOUND
It seem that the OSD still working but the screen is black. try to resolder it first because many old tv has cold solder problems.
3answers
No turn on
try unpluging convergence yoke and try turning on the set if still try looking at green lights and let me know wichone stays on ..
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
