5303L 2Way LCD Remote Start Security System Logo
Thomas LeBlanc Posted on Jan 17, 2015
I bought a car that has this remote starter with it. Time is wrong, and I don't know how to reset it. Can someone help?
marsim39
Level 1:
  • Contributor 11 Answers
  • Posted on Jan 18, 2015
marsim39
Contributor
Level 1:
Answers
11
Questions
0
Helped
1970
Points
25
What is make of the remote starter? Look on the Internet for the instructions
Antenna behind the mirror don;t know what iit is
This is normally an antenna for a power door opener or a remote starter, if you bought the car used and have no idea about this, you should have a seperate key fob that would operate the remote starter or the remote keyless entry
Want to reset ECC (ECM) on 1995 Mitsubishi Mirage 1.5L. Don't know if I am doing it right
This procedure is knowed as "soft reset", and you will must keep in mind that, if some anti-theft system is instaled there, the no start condition could appears after disconneting the battery.
Additionally, could try and check if the starter is cranked when turn ignition key, or no click sounds there? Could be a battery charge, starter or ignition swtich issue.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
I lost my viper remote starter, i already bought a replacement remote, but how do i progam it? I have the basic five button remote, black buttons and silver borders around the whole remote.
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Nissan Altima 2000 Manual. Recently had remote starter installed and was working fine for a few days. This morning I remote started the vehicle and when I came out car was off. Try starting the car up...
the remote starter is not going to damage the starter, but if wired wrong it could damage the wiring or fuses, or run the battery down from a short.
1helpful
I would like the remote control code for a Nu Tec nue3201 tv Please?
I don't know if this helps you,but it may help someone, if you set the lock on this model and forget the four digit code enter 8034 on your remote doing this will switch the tv off, turn your tv back on, after your tv is on you will see the first time installation guide, select your language retune your tv, the code will reset back to 0000. In the book it says this password cannot be reset, it also says the first time(and only the first time) you turn on your tv set, you see an installation guide. how wrong they are, hope this helps.
I need an instruction manual on how to operate a remote car starter. I have just bought a 2006 Chev Equinox with one already installed. I would like the advantages and disadvantages.Theft info,etc! Thanx...
i do not believe the equinox has a remote starter from factory so i am to assume someone had one installed. most directed electronics type alarms simply require you to press the AUX button twice to begin the remote start sequence. if this is not a Directed product then what button you press and how many times you press it may vary.
4helpful
4answers
Remote starter will not restart my vehicle
If you have an alarm, or remote start with an alarm, you need to press and hold thethe valet button which would be hidden under the dash on the driver side, as you are turning the key sometimes remote starts have a starter disable or an alarm option to reset it that is what needs to be done, some systems even if you dont have an alarm go into a valet mode if your remote battery is old or you never reset it or the alarm kicked in or what have you. if this does not work for you then you will need to bring it to a dealership and have them do a total reset to the computer you can also try disconnecting the negative battery cable, but do this with the door open cause it will reset everything, and google the reset procedure for the key fob (remote).. do that reset for the remote and it should save you money from having to bring it to a shop or dealer.
hope this helps.
2answers
SINGLE MOM CAR WONT START!!!I DON"T HAVE TIME 4 THIS!!!!
so you turn the key and the starter does nothing... i would suggest that you attempt to start it while someone hits the starter with a hammer... not that gently but don't break the starter either.
If it suddenly turns over you need a new starter. and right away because using a hammer only works a few times.
Robert
Incidentally it was minus 20 here last nite lol
Ks360 calling problem
i had the same problem for arround 3 months. almost a month after i bought the phone -- this is really really anoying. what i did was to clean all the messages i had in the memory. it worked out. i don;t know if it will work for you but try. also try reseting the phone. i did the same and it helped.
Top Avital Vehicle Parts & Accessories Experts
john h
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
