Question about Samsung SF-5100 Plain Paper Laser Fax
Samsung sf5100 fax shows "fuser error" and I cannot receive faxes but can send ok
Posted by patrick_keow on
Kevin Cole
    New Friend:
  • 45 Answers
The fuser unit will need to be replaced. It's possible that the heat lamp or thermostat of the fuser has failed, but getting those individual items could be difficult. The fuser unit should still be available from a Samsung repair center. Search on line for your nearest authorized dealer. You will continue to be able to send regardless of the fuser.
Posted on Dec 08, 2009
Our fax machine says recieve error and will not recieve faxes
I presume the machine has its own telephone line. Lift the handset and make a telephone call. Can they hear you ok? Can you hear them OK? If both ok then have them ring the fax and you answer it with the handset. Can they hear you ok? Can you hear them ok? or can you hear crackle on the line or any other strange high frequency noises? If you hear these noises then your telephone company will need to clean the line. Thats usually why this problem arises. the SF5100 was Samsungs best fax in my opionion. It did not suffer from any problems except wear and tear like all machines.
Jul 21, 2011 | Samsung SF-5100 Plain Paper Laser Fax
DISPLAY ON SF5100 SAYING FUSER ERROR
you must check the fuser unit. sumtimes it is the bulp or the thermister.
Feb 08, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Message showing FUSER ERROR??? Please could you tell me what this error is and can it be fixed?? Thanks Suze
This is a error whit our fuser unit. this the part in front of your fax which is hot. check the bulp inside. if it is ok. check the thermister
Jan 19, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Samsung sf5100 fax How do i replace the toner
Open front cover,then pull out toner and in the middle you will see a tiny fuse. Take it out and put a new one in. Put back toner,close everything and let it run.
Sep 11, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF5100 has a loud buzzing noise
Hi there you might have a faulty toner cartridge is it a original or has it been refilled? I suggest to install a new toner cartridge and hopefully that will cure the fault. If this dosen't there maybe a small piece of paper stuck in the cartridge or after the toner cartridge within the heat section open the back of the machine (the jam door) and check there is no paper.
If the printed document is getting stuck just after the toner cartridge it will most likely to be the heat section will need replacing.
Hope this helps you and please rate me
Thanks J
Dec 31, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF-5100P
Machine will require fuser(hot bit at rear) replaced before it will operate, take to dealer for quote or if brave and 240v happy then buy a fuser and get your tools out rip off the covers and in the back you will find fuser assy.
link to service item fuser U.S.
http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=JC96%2D01621A&search%5Fmodel=SF5100
Nov 14, 2007 | Samsung SF-5100 Plain Paper Laser Fax
SF5100 DOES NOT TRANSMIT ALL THE TIME
There maybe 1000's of reasons for this but the most common is that the ECM mode is turned on (ECM =Error Correction Mode) turn this off and try. There is one other common fault try doing a copy of a document and see if that come out ok. If you are getting the same fault the scanner unit is faulty and will need replacing.
Hope this helps and please rate me
Cheers
J
Oct 25, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF-5100 Plain Paper Laser Fax Logo
329 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
