Question about Samsung Refrigerators
MY SAMSUNG FRIDGE/FREEZER HAS A PROBLEM MY TEMPERATURE ON THE FRIDGE IS FLASHING. THE MODEL NO. RS21DCNS THE FRIDGE IS NOT COLD ENONUGH AND I PUT THE TEMPRATURE ON HIGH AND IMMEDIANTLY IT WENT BACK DOWN. AT THE BACK OF THE FRIDGE THATS WHERE THE NOISE STARTS.
Posted by mauz23 on
Anonymous
This is caused by the ice building up in at the back - the fan catches the ice and eventually will stop. With the fan malfunctioning the temperature will rise and the light then flashes. Keep searching the web, and you will find instructions how to remove the back and de-ice it. I had exactly the same problem 2 months ago. Make sure that it is fully de-iced, including the tray at the bottom. Ours has worked OK since!
Posted on Aug 08, 2009
Samsung RS21DCNS Water dispenser freezing up
Sounds like you have the freezer temperature set too low.
Oct 09, 2009 | Refrigerators
Samsung RS21DCNS Fridge not getting cold
0845 726 7864 samsung know of this problem and are doing free fixes to all of them just phone the number it doesnt matter about the warranty as they have extended them all free to 5 yrs.
There are numerous problems including noisy fan that stops when doors open to no water and all are free to fix.
Hope this helps.
Sep 01, 2009 | Samsung RS2556 Side by Side Refrigerator
SAMSUNG RS21DCNS
samsung fridge freezer problem
samsung fridge freezer diy help
Apr 27, 2009 | Samsung Refrigerators
I have a samsung RS21DCNS fridge but i have jus had apower cut for 10mins and now the fridge is not working. the lights are coming on inside but there is nothing on the contol panel and none of the buttons...
unitl you either cleanr the code or repair the fault that is what you see.the fault is the ice maker sensor is not reading correctly. check the plug connections for the sensor. if you would like you can contact me and i will help you with this problem.
Jan 17, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge and freezer not staying cold but lights and fan working
the problem is going to more then likely in the main control board which is on the back of the refrigerator in a little compartment this board is bad about going out if you have power surges or outages
Jan 03, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung side by side
you can reset the fridge by pushing "Power Freeze" and "Power cool" at the same time
it worked with my fridge Samsung RS21DAMS which stopped after a power cut and was also flashing at the digit of the fridge temp display
Mar 28, 2008 | Refrigerators
Refrigerators Logo
571 people viewed this question
Top Samsung Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
