There are way too many ways to wire this unit to other components. You can buy a GM wiring harness and integration box to fit your truck that will get you power and factory speaker wires to connect to the unit. If you plan on using navigation or amplifiers, those and other options are custom and will vary with your needs. Check out the metra pages to fathom the possibilities.
Just touch the clock. It's actually your screen saver and you can then it off in your settings. But I'd you just want a different clock, simply touch the clock and it'll display another style.
I grounded my Jensen to a screw inside the dash. I had to put a switch on it though - Jensen requires an on-off-on sequence with the parking brake, which applies and removes the ground. I duplicate this by throwing the switch. Check the manual or online references to see if you have to do this. If you do, you'll need a switch. If not, you can just ground the wire.
