Question about Staples SPL-P500 Printing Calculator
How do I get the date and time to print on the receipt when I am completing a calculation?
Posted by Marilyn Gardner on
My Sams 4s 5200M is printing second receipt..how can i fix?
I found this:
"print multiple receipts
1. system option programing p124,125
- 30 [ST] 6 [X/time] 4 [ST] [CASH] [cash]
2. print option (manual p130,
- 40 [ST] 24 [X/time] 1 [ST] [CASH] [cash]
Note: multiple receipts are printed by pressing the [Cash] button again after the sale is completed.
http://www.hotpos.com.au/resources/file/HOTPOS-ER-5200-Programming.pdf
Anthony
Jul 09, 2018 | Retail Supplies
How do I calculate Total number of weeks merchandise has been in stores give first receipt date & last receipt date exampl
Convert the dates to Julian format using the online Naval Observatory calculator. Subtract and divide by 7. Round up. 2456880.5 minus 2455616.5 = 1264 days or 180.57 weeks. Use 181
http://aa.usno.navy.mil/data/docs/JulianDate.php
Oct 05, 2014 | Computers & Internet
Print receipt casio
Next to the date/time button , there is a button written receipt/on/off
press that one once...good luck
Jul 08, 2013 | Casio PCR-T2000 Cash Register
Setting date and time, I put in correct date but doesn't stick ,
Start by pressing down on the clock/calendar button for about 3 seconds. Then press the equal ( = ) sign to input the correct date. Same process for setting the time. then press the ce/c button to clear the data on the screen. When u want to print the date, press the calendar button. this will automatically print it. then press the ce/c button again so u can start calculating.
Apr 08, 2010 | Canon MP-11DX Calculator
Setting the time and date
To set the date, make sure that you are in Rate Set. type in the date such as August 3, 2010 would be entered as 08.03.2010 then press the date time key. This will set the date. To set the time type in the time such as 4:20 PM would be entered as 16.20 then press the date time key and this will set the time.
Feb 02, 2010 | Sharp EL-1197PIII Calculator
Date and time reset
To set the time: First set to Rate to "SET" then say for example the time is now 1:33 p.m. enter 13 then hit the decimal then enter 33 hit the decimal then hit the time key and you are set.
Jan 22, 2010 | Sharp EL-1750PIII Calculator
Need to change the time on calculator
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position.
Date:
Enter in the order of month, day and year, then press date/time button
to complete the entry.
Use ▪ to separate month, day, and year EXAMPLE 3▪13▪2009.
When (date/time) button is pressed, the number entered is evaluated
and displayed as “date”
Time:
Enter in the order of hour, minutes, then press date/time button to
complete the entry.
(There is no entry available for the seconds value. The
clock starts at zero second.)
Use to separate hour and minute values EXAMPLE 8▪15
When is date/time button is pressed, the number entered is evaluated
and displayed as “time
When settings are complete place the switch back to GT
Mar 11, 2009 | Sharp EL-1197PIII Calculator
Helps with time - - - - what about date - that doesn't seem to work
try this one have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved.
Jun 25, 2008 | Office Equipment & Supplies
How to get the date and time to print?
There is no date/time function on this model. Here is the link to the manual:
http://www.sharpusa.com/files/cal_man_EL2630P.pdf
Thanks for using and rating FixYa!
Dec 21, 2007 | Sharp EL-2630P Calculator
How to print date and time?
If you download your manual from here: http://www.sharp.ca/manuals/, you will have exact instructions with illustrations. Thank you for using and rating FixYa!
Staples SPL-P500 Printing Calculator Logo
242 people viewed this question
Top Staples Office Equipment & Supplies Experts
gbob59
Marvin
Marvin
Vernon Taylor
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
