Curtis Klu 7-inch Touch Screen Mobile Internet Device Logo
k
kcalonnie brooks Posted on Jan 16, 2015
My tablet is charged but it wont cut on how can I reset my tablet
Plugging it up to charger
My kocaso tab wont turn on whille charging
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
My tablet wont charge what can I do I try to plug in charger but won't charge the battery even bought another charger still dont help
Most likely you are using an aftermarket charger. You may want to purchase another or buy and OEM charger.
Why will my ipad not charge and what do I need to do?
try resetting it, power it off completely. If still not working check charger on another device to make sure charger is OK. If it is you will need to have it repaired, new battery or charging circuit or new socket
M1070 wont come on just flickers
No power
Wont start up
MY TABLET WONT TURN ON
RCA tablet wont charge
Possible charger damage.
If you know someone with a charger you could use, you should first plug their charger into your unit to see if it works, if not, plug your charger into their unit.
If your unit will not charge with new charger, you may have serious damage, if the other will not charge with your charger, your charger is broken.
Tablet wont charge
The charger socket has probably broken its solder connections, happens because of repeated movements straining it by using it when the charger is plugged in. Have you tried charging it through the mini usb socket?
Motorola xoom wont charge
this is very common/same problem lots people having with their tablets, but i recently found solution for it.... try the following.
first connect ur charger to the table as you normally would do for charging, then connect the tablet to the computer through the USB wire (make sure charger and usb wire both must connected to the tablet) and it should start charging.... this seem awkward but will 100% work try it and see it urself
Top Curtis Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Curtis Tablet and eReader Expert? Answer questions, earn points and help others
