Re: My tablet wont turn on I tired lots of ways to try in...
This same problem has happened to me too. My rca 10.1 inch tablet wont turn on any more and I had it for one month too. I tried the reset button and it doesn't work.
It sounds like you've done most of the things you would reasonably be expected to do to make it function; since it is only 2 months old I would strongly urge you to go back to the retailer and make them replace it or refund you, as your rights in most countries/states allow.
If you're set against doing this, try holding down the power and volume down key for at least ten seconds to see if this boots it into hard reset mode. If this doesn't do anything, try again holding down power with each of the other buttons to see if you can activate any other developer/reset modes.
However, I have read reports that this particular tablet has up to a 40% failure rate in its first six months.
If you can possibly get it refunded, do that and buy something else.
Try this: Turn off the tablet, then Hold down the Vol + and Vol - at the same time for about 10 to 15 secs. If this takes you to recovery console, do wipe/factory reset.
There should be a tiny reset button or pinhole (use a straightened out paper clip). If reset button/hole itself does not work, try pressing it while holding down the power button at same time. Otherwise, it sounds like you have a battery/charging issue (try another charger cord if available).
Try using a paperclip to reset it on the back, hold it in for 5 seconds, if that doesnt work: Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
try holding power button in for about 15 seconds or untill you hear the crackel sound that means is totally shut down. then try to turn it back on. grandson just had this problem. he had put it in sleep mode by not turning it all the way off.
