It is a tv-dvd combo wont stay on but a few secons
SOURCE: toshiba md20p1c tv power won't stay on
The problem is Q401. Change it. It is a 2SC1624 but a 2SC1018 will also work. This solution will work for other Toshiba P combo units.
SOURCE: Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
SOURCE: Toshiba TV/DVD combo turns on then off again.
try letting it sit for 15-20 minutes unplugged from the wall and maybe try another outlet depending on if u got plugged in to a power strip, possibly pulling to much power from that perticular outlet.
SOURCE: toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
