Question about Sharp AR5316 Black Toner / Developer Cartridge Genuine
<!-- from fixya rte -->I have sharp ar5316 coming white copy - Sharp AR5316 Black Toner / Developer Cartridge Genuine
Posted by Mohammed Raheem on
iftikharhmd40
    Sergeant:
  • Sharp Expert
  • 229 Answers
Change toner cartridge
Posted on Jan 16, 2015
5 Related Answers
checkitright
CheckitRight
  • 1363 Answers
SOURCE: sharp ar5316 blank pages printed and copied.
while standing in front of the copier open the Right door and then then flip down the Front door. Are the levers in place ? usually the front door will not close properly if not.
Second take out the toner and look for a loosely hanging piece of plastic on it, give it a tug, does it seem to be a long peice of clear plastic? if yes yank it all the way out. It is a protective piece sent for shipping. It will be on ALL the toners you get.
If not look at the right side door there is a back assembly there with either a black cylinder type roller or some strings.
Are the strings broken , is the roller in place?
Posted on Oct 25, 2007
Rick Kasper
  • 2072 Answers
SOURCE: sharp copier AR5316
H2 or 2H is related to a fuser under heat or overheat.
Try this first,
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
If this does not clear the problem the fuser will need replaced.
Posted on Feb 21, 2008
Anonymous
  • 24 Answers
SOURCE: sharp ar5316 code U2
Try reset code sim 16 in diagnostics.
Type p * c * machine will go into sim mode
type in 16 then start.
press CA
machine will turn off then back on.
Posted on Sep 05, 2008
Anonymous
SOURCE: AR5316E error code h2
hi in put # + inroput + c + intrupt + 14 + start
Posted on Mar 07, 2009
Anonymous
  • 7 Answers
SOURCE: SHARP AR5316 SHOWING PAPER WHILE NO PAPER JAM
try to chek if the actuator of the exit sensor is ok you will find it when you open the side door exactly attached to the heater try to check the end is it in plase or not if not use sim 30 sub1 to check all sensors you wil solve your problem
Posted on Mar 23, 2009
I want the drivers for Sharp AR-5320
http://support.sharp.net.au/drivers/, GO TO THIS LINK, CLICK PHOTO COPIERS AND DOWNLOAD AR5316. RATE THIS AND VOTE FOR THIS
Apr 05, 2011 | Sharp AR-5320 Black and White Copier
Sharp ar5316 driver for windows 7
unfortunately, Sharp only supports this model in Windows 95, Windows 98, Windows ME, Windows NT, Windows 2000, Windows XP only
Jan 04, 2011 | Computers & Internet
Driver download
You need to go to the sharp usa site. You will go to office products and search ar5316. They have a driver section there and you can download one of probably 3 drivers. I would suggest PCL5 or PCL6 for black and white copiers. PS driver if you copy a lot of PDFs.
Aug 27, 2010 | Sharp AR-5316 Advanced Digital Imager...
How to change destination settings?
go to cod condition(# interrupt c interrupt) LCD turns off.enter 26 press copy enter 6 press copy enter 4
then copy.
May 20, 2010 | Sharp AR-5316 Advanced Digital Imager...
How can i scan an image to computer with sharp ar5316e
The Sharp product description page lists this device as a printer/copier. It's scan function will only produce local copies on itself and it will not scan to another device or computer.
May 27, 2009 | Sharp Computers & Internet
Mar 07, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Driver
Appreciate the direct "Ask Me". For Sharp AR5316/AR5320 drivers, pls click here. The drivers are for Windows 95, Windows 98, Windows ME, Windows NT, Windows 2000, Windows XP only.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 17, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR5316 Black Toner / Developer Cartridge Genuine Logo
74 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
