Sony Ericsson P990i Cellular Phone Logo
Question about Sony Ericsson P990i Cellular Phone
Charger do not fix well with Cellphone Charging Port
I have P990i for last Two years. Now, my charger/data cable/hands free do not properly connect with the USB port. I have to move them up-down-left-right in order to connect them properly. However the New charger fix properly without any problem. I am not able to understand whether my Data Cable/Charger/Hands Free connector are bad or My Phone USB port is bad. Please help, How can I fix this problem
Anonymous
    Sergeant:
  • 326 Answers
The bottom connectors gone bad replace it
Posted on Jul 07, 2009
2answers
I need a usb charger What can I do?
The problem of your getting usb charger can be solved by this site. This is not a usb charger but also a charger of multi ports. It has 6 ports each port is providing 2.4 A what is so demandfull for any kind of usb charger. Go and check it out.
http://www.amazon.co.uk/dp/B00MGJAXC8/
P5113 not charging properly
There are a couple of common problems that can cause bad charging:
  1. Bad charging cable - try a new cable
  2. Bad charger - try a new charger, or try plugging it into a PC USB port overnight with the PC turned on
  3. Charger is not the right charger for your tablet - Samsung devices are known for being picky about what charger you use. If you don't use the original charger that came with the device, or a Samsung charger made for your specific tablet, you will have trouble.
  4. A bad/broken charging port on the tablet - this is not something you can fix yourself. You would likely have to return it to Samsung for repair, or find a local repair shop.
MY NOKIA CELLPHONE DIDNT WORK PROPERLY
Hi:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
My lg shine wont turn on. I didnt charge it last night and it died this morning so i plugged it in for a good half hour and it still wont turn on.
Hello Ashlea
First of all make sure that the charger and the cellphone is connected properly to each other. There should be some activity going on in your cellphone indicating that it is really charging. Can you see that activity? If not, try plugging the charger on a different location. If it is possible, try a different charger.
Update me what will happen so we can continue.
3helpful
2answers
My phone keeps beeping when in the charger unit
Without knowing why type of charger you are using this is difficult to answer, but more than likely it is that the charging is getting interrupted. Another words, the charging cable is not making a good connection. This would be the port on your phone where the charger goes into your phone or it could simply be your charger cable. Try using another charger and see if you have the same symptoms with another charging cable. If so, then it is more than likely to charging port on your phone. Recommendation at this point would be to take it to your cell phone carrier so that they can make sure it is indeed your phone, they would advise you from there. Hope this helps.
1helpful
No power mp5 i use a cell phone charger in my mp5
What you will need to do when mp3 player does not charge. First use another charger to test if it's the charger is working properly.
And secondly After testing for charger, and still it does not charge, that means the charging port on the mp3 player where the charger is been plugged in is not working properly. You will need to replace the charging port.
Alternately you can charge it from your computer by using USB cable. It automatically charges when connected to a USB port
My cp is not charging...
when a phone does not charge, it means that the charging port is faulty and needs to be replace.
On the other hand, you can check the charger also. You can use another charger to try it out and see if it will charge.
Take care.
2helpful
In my sony ericsson P990i cellphone when i charge it it will not be charged.the charger and battery is ok .so please tell me what should be the problem and the way to solve the problem. thank you
check the pins on your charger and the connector on the phone. if they are in order, then u have a problem with your charging port which is on the phone. and if that is the case, you may have to replace the charging port. alternatively, you can get an external charger and use it to charge the battery. meaning you will get an extra battery to swap with the other when one is on charge. but if this problem deteriorates, it will be running down your battery,making it to discharge faster. Cheers!
1helpful
2answers
Motorola E680i not charging properly
charge port prob lo...just change new port or do it ur self
My cellphone
The 20 Pin USB, charger....sometimes gets a little messed up (I sell ATT) the pins inside are not connecting to the proper port. I would suggest trying to get a new charger....try a car charger first....then if that does it, get an iGO from radio shack or sams clubs. (1 tiny pin can disable it from charging)
Top Sony Ericsson Cell Phones Experts
Muzahura Frank
Marvin
Marvin
George Etukudo
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
