Question about Symphonic ST419E TV
Fix my symphonic video setting so i can actually see how to play my game
Everything
Posted by Kevin oscar... on
HBO go can't play video. How to fix it?
Hello friend...
"Can't Play Video" just follow these steps to fix this issue:
1.In the upper-right corner of the Chrome browser, choose More (appears as 3 dots), then choose Settings.
2.In the 'Search settings' edit box, type Flash and press Enter.
3.Click Content settings.
4.Click Flash.
5.Turn on Allow sites to run Flash.
6.Open HBOGO .com in a new browser window and try playing a video.
For any help visit us: HBO Go Help
Jun 11, 2018 | Video Video Game Consoles & Games
My set was zapped by a nearby lightning strike. The screen still works. But it won't do anything past the "Vizio Internet Apps" screen. It then times it and shuts the screen off. It is a model #E422VA
Pull the plugs on everything - going to everything, starting with the TV and on out. Let everything just set for 20 min. Then, hook everything up to the TV BEFORE you plug in the TV. Turn it on. Good luck. . .
Apr 11, 2017 | Televison & Video
How to turn a symphonic tv into game
symphonic is well known for this-no buttons on unit for key features and a universal is not going to help either, suggest you go in search of the original remote and hang onto it.....
Aug 28, 2012 | Televison & Video
How do I get my symphonic TV to video mode without a remote
no possible unless set has actual video or input button on it---almost all the Symphonic sets only have this feature on the original remote.
May 14, 2012 | Televison & Video
Trying to connect a Sega Genesis. I know it's connected properly to the place where the cable wire goes and then that is connected to the connector. What channel do I go to to play the games?
The input from the Sega wont be on any channel number - you need to select the correct input for the Sega using the "INPUT SELECT" button on the Symphonic remote control supplied with the TV. Switch on the TV the Sega, then press this button repeatedly until you can see the picture from the Sega.
- If you are using the sockets on the BACK of the TV, the correct input is "VIDEO 1"
- If you are using the sockets on the FRONT of the TV, the correct input is "VIDEO 2". You can also switch to the "VIDEO 2" input by pressing the "GAME" button on the Symphonic remote - if you still have it.
If you don't have the Symphonic remote, look for a button marked "INPUT" or "SOURCE" if you are using a universal remote.
If you don't have any remote for the TV, you will only be able to use the sockets on the front of the TV. You will then need to switch to "GAME MODE" by using the buttons on the front of the TV:
1. Switch ON the TV and the Sega;
2. Press the MENU button;
3. Press the VOLUME UP button to open the PICTURE MENU;
4. Highlight GAME MODE using the CHANNEL UP/DOWN buttons;
5. Set GAME MODE to "ON" using the VOLUME UP/DOWN buttons;
6. Press MENU again to close the menu
You should now be able to see the picture from the Sega. If not, check you have correctly connected the Sega to the TV. When you have finished using the Sega you will need to use the method above to switch game mode off again.
Hopefully, I've covered every possible angle. If you have a different Symphonic TV model from the one listed above (ST420FF), the method should be similar, but if you have any difficulty, please post back for further assistance.
BElectric.
Jan 16, 2011 | Symphonic ST420FF 20" TV
My wii system lost its red color. when i play wii sports everything mostly everything is green. i tried fixing my tv settings but its not the tv. ive tried everything. does anyone have a different idea on...
I have the same problem with my Wii. It's on everything, games, etc. Did you ever access the internet through your Wii. I do and I wondered if a virus hit it.
Sep 10, 2010 | Nintendo Wii Console
Symphonic ST419E TV Logo
Top Symphonic Televison & Video Experts
Steven Wander
Steven Wander
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
