My LOGIK L22DVDB19 was working O.K. We had to turn the Power-Off for work to be carried out. When the POWER was turned back on, everything worked save for the TV?- No red light on: can anyone help?
1, changing the fuse. 2, Using manual control on TV
Posted by David Wilson on
Andrew Lohbihler
    Master:
  • 505 Answers
Check that the power cables were properly seated to the power board internally. If your TV is not starting at all, then likely this occurred, or that the cables are not seated properly to the TV. Any number of things can happen when you do servicing to the TV, assuming that had happened.
Posted on Jan 25, 2015
5 Related Answers
Anonymous
SOURCE: red power light flashing but no picture
Ditto for Jan 13th with a Panasonic 50"!
Posted on Jan 14, 2008
trunking
SOURCE: SVA HD4208 42INCH Plasma will not turn on.
I called the factory or the distributor or wholesaler (customer service) that comes out on the web and they told to just buy a new remote cuz tv just isn't recognizing the remote. Can this be true? If this is far from being true, where do I buy the boards and what are the chances that the boards are the real problem?
thanks once again.
Trunking.
Posted on Feb 12, 2008
tvrep
SOURCE: Panasonic 32" HDTV keeps turning off
Check or have a repair tech check connectors AP1 and AP2. Vibration rattles the power supply board (a crappy design, as the board is almost "floating") and causes the wires in the connectors to break, and may make intermittent contact. Heat may also cause intemittent contact. A very common flaw.
Posted on May 06, 2008
Anonymous
  • 1139 Answers
SOURCE: Hitachi 55" Plasma HDTV, 1 yr old, suddenly lost picture and sound, but power light still on.
It sounds like a shutdown circuit is being activated. This is normal in cases where the power supply id drawing excessive current. I would suggest that you get this looked at by a qualified professional. This is because this problem may be in the power supply and the voltages can get dangerous in this section of the TV set.
In any event if this is a power supply problem chances are the technician will just have to replace the power supply. Which should cost from 150-250 dollars.
I hope this helps
Shuttle83
Posted on Jul 14, 2008
Anonymous
SOURCE: Magnavox 50" plasma Won't Power on/Shut's off/Blinking red LED
The above fix, listed by Tom saved us!! We did as instructed and took off the back of our 50 inch Magnavox plasma tv. We were not sure what we were looking for so we googled capacitator (image) & there was a photo of a fried capacitator! Sure enough we noticed ours were "fried", we took out the board and went to an electronic supply store, bought the 2 capacitators ($2.00 each!!) and then found someone who did tv repair to sauter the new capacitators onto the board. (It is important someone who know how to sauter and recognizes polarity do do this for you) All in all we fixed this following the above instructions for $34.00 and our time. For a month we were told to spend hundreds getting a new power board!
Kudos to you Tom & thanks so much!!
Posted on Feb 02, 2009
My vw Passat 16 plate infotainment doesn't appear to be working, I have lost all radio stations bar a couple, it won't save them anymore, when I save one and stop the car lock it and get back in everything...
It has lost battery power. It has 2 power sources. The battery is constant, no fuse. This is for the radio memory. The ignition is fused, it is the one that turns the radio on. You have to pull the radio plug and check for battery power. If it is there, you have an internal radio problem.
May 04, 2016 | Cars & Trucks
Tip
How to repair a vizio tv that turns off at random
1.) Unplug everything from the TV [power, hdmi, av, and more]
2.) Because the Vizio holds power while unplugged you can reset it while its unplugged.
3.) hold power button on the tv down for about 60 seconds.
4.) plug the power only back in.
5.) turn tv on
6.) if it works then plug each component in one by one
7.) enjoy your tv
8.) start saving for a non vizio tv.
on Apr 07, 2010 | Televison & Video
I bought a Logik car radio but every time I switch my car on I have to set the station and the time all over gain.. I dont even bother to set the time because it changes back to Midnight every time I
you forgot to hook up wire to fuse box with all time connection to power even when car is off.if u connected thw stereo red wire positive black ground theres always another wire yellow/blue/orange that needs to be connected to constant power that wire once connected will have all ur memories stations set and clock.ned to check wiring
Mar 03, 2014 | Car Audio & Video
Logik LED TV making a constant tapping/clicking sound.
try turning off AND unplug for a couple minutes! USB may have pulled power down to start the switching noise. Try usb again and if it does it again then I wouldn't use that usb anymore.
Jan 17, 2014 | LG Televison & Video
L22dvdb19 dead
you must bring to tv repair shop. They will preform cpr & get it working.
Nov 20, 2012 | Cell Phones
Computer not working
try to turn off the pc ,remove the cables and then press & hold power button for 8 secs. Reinsert cables and battery then turn it on.If it did not work,call your pc manufacturer..
Aug 13, 2011 | Computers & Internet
LOGIK L22DVDB19 22'' unlock code to watch region 1 dvds
All you need to do to access region code choice is have the dvd tray in the open position and then press 9735 on the remote control.
The engineer menu will appear on the screen which allowsyou to select the region. Select Region 0 for multiregion, once selected you will not need to do this again.
Mar 08, 2010 | Televison & Video
Logik LCD 32 Signal problems
Have you tried having your outdoor antenna upgraded? and do you have an antenna booster in the back of the tv where all the antenna cables connect into.
Nov 05, 2009 | Televison & Video
Dell Monitor in Power Save mode
Hello there:
i would refer to your users manual to see if there is a power save mode setting on the monitor it'self and to see how to adjust it or contact the manufacture of the monitor . ok ?
hope that this is helpful
Aug 06, 2009 | Dell E173FP 17" LCD Monitor
Pc entering power save mode
I am having the same problem . The system is starting up and th epc entering power save mode. I have a Hp pavilion f1503 model monitor. I hit the power off button on the power surge to shut the entire power off. I turn the power surge button back on. Sometimes it works. Or have to hit the power on button to reboot.
Dec 12, 2007 | HP Pavilion a810n (PP164AA) PC Desktop
Televison & Video Logo
153 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
