Computers & Internet Logo
P
Philip Young Posted on Jan 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
<!-- from fixya rte -->Remove error messages from my computer - Computers & Internet
joecoolvette
Level 3:
  • Master 5,660 Answers
  • Posted on Jan 15, 2015
joecoolvette
Master
Level 3:
Answers
5660
Questions
0
Helped
2193356
Points
18014
1) Computer off unplug from power.
2) Press Power On button in, hold for a count of 10 seconds.
Let go.
Do this procedure 2 more times.
3) Plug back into power, WAIT 1 minute, turn on computer.
The aforementioned procedure resets CMOS back to the factory default settings, and clears CMOS Error Codes.
Doesn't work? Then whatever is causing the error code/s are still present.
For additional questions on this matter please post in a Comment.
Regards,
joecoolvette
1helpful
Power went out... when came back on got the message "error loading operating system"
While at this message remove any USB storage devices plugged into the computer (Cell phones, USB thumb drives, external hard drives) also eject any CDs and Floppies. Turn the computer off and back on. If the issue persists then it is possible that the power failure damaged a physical component of the computer.
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Mensaje al cargar mi compu Vaio Sat Survey. exe has stopped working
    The VAIO Sat Survey is an Application that loads at the Startup. If the Application in the Computer is corrupted, it will display an error message that the "VAIO Sat Survey has stopped working".
    You can just remove the "VAIO Survey/VAIO Sat Survey" from the startup items to fix the error message.
    Please follow the below steps to disable the Application from starting automatically and fix the error message.
    1. Open the run window by pressing the "Windows" and the "R" Keys.
    2. Then, in the run window, please type "msconfig".
    3. This will open the "System Configuration Utility" window.
    4. In the System Configuration Utility window, please click the "Startup" tab.
    5. In the startup tab, please scroll down to view the "VAIO Sar Survey/VAIO Survey.
    6. Then, please remove the check mark next to the above items.
    7. Then, please click the "Apply" and "OK" buttons.
    8. The Computer will prompt to restart.
    9. Please restart the Computer.
    10. The error message should not be there when you restart the Computer.
    Vaio sat survey not working
    STOP C0000221 erro de hardware desconhecido systemroot system32 ntdll.dll
    You may receive one of the following stop error messages while working on your Windows XP computer.
    STOP: C0000221 unknown hard error
    Path\File_nameSTOP: 0xC0000221 unknown hard error
    C:\Winnt\System32\Ntdll.dll (or another specific file or driver)
    STOP: 0xC0000221 STATUS_IMAGE_CHECKSUM_MISMATCH
    Path\File_name
    Note: The error message may be discussed in many different formats-blue screen or message box. It depends on when the corrupt file was detected.
    Similarly, you may receive the following STOP messages when a critical system file fails to load on your Windows NT and Windows 2000 computer.
    <path>\<file_name>STOP: 0xC0000221 unknown hard error
    c:\winnt\system32\ntdll.dll
    Note: Some other drive may also be given in the message.
    On Windows 2000 the following error message may display:
    <path>\<file_name>
    You usually face this problem when an incorrect driver for one or more hardware is installed on your system. For instance, the error messages described above are displayed when you install a millions of instructions per second (MIPS) driver on a x86 system.
    Cause of the Error
    This error occurs if the file given in the error message is damaged.
    Your Windows XP operating system checks the following files for integrity during system startup:
    • All driver files, excluding the files that loaded using the system loader to start your system .
    • All DLL (Dynamic Link Libraries) on the system. These include, Graphics Driver Interface (GDI), User, Ntdll, Crtdll, Shell, Kernel and several other DLL files on the system.
    • On Windows NT and 2000 computers, all DLLs loaded in the Window server address space are also checked.
    The problem may also occur if an Iomega Zip drive is connected to the same cable as your hard disk drive.
    Resolution Method
    You can resolve this issue by removing the corrupt driver from your computer and then reinstalling a fresh and healthy copy of the driver. You may need to use the Device Manager utility to remove the driver. It is recommended that you clean your registry with the help of a reliable tool, such as RegGenie to ensure that all entries related to the uninstalled driver are removed from the system. After you have completely removed the corrupt driver, restart your system and install a fresh copy of the driver on the system.
    If this step does not resolve the problem, you may have to reinstall Windows XP.
    It is recommended that you regularly clean your registry with the help of a registry cleaner tool and perform antivirus and antispyware scan using tools, such as Antivirus Plus and StopZilla to prevent such errors from occurring on your system.
    GOOD LUCK :-)
    Check print cartridge blinking cartridges refilled today and installed laptop not recognising printer as result
      • If the message on the computer does not identify a particular cartridge (it says only Print cartridge error ), follow the steps below to determine which cartridge is causing the problem.
        1. Open the cartridge access door.
        2. Remove either cartridge (not both).
        3. Close the cartridge access door.
          • If the computer message is Print Cartridge Error , then the print cartridge that is still in the printer is the problem cartridge.
          • If the computer message is NOT Print Cartridge Error (instead, it says that the cartridge you have removed is ...Either missing, not detected, or incorrectly installed), then the cartridge you have removed is the problem cartridge.
    • If the problem still occurs, the electrical contact between the cartridges and the printer might be bad. Removing and reseating the cartridges might help. Also, you can clean the electric contacts on the cartridges with a dry cloth.
    Hope that will help solve your problem!
    Get multiple error messages that a particular
    download the mccafee remover some installer of mcafee cont uninstal but they have mcafee remover..
    1helpful
    2answers
    Keep getting replace yellow ink cartridge error message
    Where did you get the error message on printer or computer?
    If you get the message on printer remove all cartridges and reinsert the cartridges and align the ink cartridges. If the alignment page prints successfully then the problem is resolved.
    If you get the message on the computer disconnect the usb from computer. uninstall the software and reinstall the full feature software by selecting connect USB later.
    1helpful
    Switch computer on and the light is red but on the screen it says system error contact xbox customer support
    SYMPTOMS loadTOCNode(1, 'symptoms'); You receive the following error message in multiple languages: System Error. Contact Xbox Customer Support. CAUSE loadTOCNode(1, 'cause'); Typically, this error message is caused by a hardware failure. THINGS TO TRY loadTOCNode(1, 'whattotry'); Note If you receive an error message and see one flashing red light on the front of the console, see the following article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/) Xbox 360: One red light flashes on the Ring of Light and you receive an error message 1. Turn off the console, disconnect and then reconnect all cables. Turn the console on again. 2. If an Xbox Hard Disk Drive is attached to the console, turn off the console, and then remove the Hard Disk.
    For more information about how to remove the Hard Drive, click the following article number to view the article in the Microsoft Knowledge Base: 906204 (http://support.microsoft.com/kb/906204/) Xbox 360: How to attach or remove the Xbox 360 Hard Drive Turn on the console, and then test for the error message. If you do not receive the error message, turn off the console, and then reattach the Hard Disk. Alternate testing with the hard drive connected and removed to see whether the error message occurs only when the hard drive is attached. If the on-screen alpha-numeric error is E67 in the error message, see the following article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/) Xbox 360: One red light flashes on the Ring of Light, and you receive error E67, E68, or E69 3. If an Xbox Memory Unit (MU) is plugged in to the console, turn off the console, and then remove the Memory Unit. Turn on the console again and test for the error message. If the error message does not reoccur, turn off the console, and then reinsert the MU. Alternate testing with the MU inserted and removed to see if the error message occurs only when the MU is inserted. 4. If you continue to experience this behavior, contact Xbox Customer Service.
    LaserJet 2420dn Error
    The error means -
    A critical firmware error has
    occurred.
    Recommended action
    1. After performing the actions
    listed in the preceding item, if
    the message persists when
    using different software
    programs and attempting
    specific print jobs, disconnect
    all cables that connect the
    printer to the network or a
    computer.
    2. Turn the printer off.
    3. Remove all memory DIMMs
    or third-party DIMMs from the
    printer. (Do not remove the
    firmware DIMM in slot J1.)
    4. Remove all of the
    EIO devices from the printer.
    5. Turn the printer on.
    6. If the error message
    disappears, reinstall
    each DIMM and EIO device
    individually, making sure to
    turn the printer off and then
    on again as you install each
    device. To replace a DIMM,
    see.
    7. Replace the DIMM or
    EIO device that caused the
    error message.
    8. Remember to reconnect all of
    the cables that connect the
    computer.
    9. If this error message persists,
    replace the firmware DIMM.
    10. Replace the formatter
    Grand Canyon Tech
    Grand Canyon Tech
