SOURCE: How do I calibrate my BPA-430WGN blood pressure
send it in to Homedics for $10 and they will do it for ya
SOURCE: What is the data link for on the HoMedics #518729
There was supposed to be Healthvault software from Microsoft. Along with a optional USB adapter (from the micro port on the BP machine to the computer USB port) the software uploads the blood pressure data to a site where it can be shared electronically with those you choose, like several different doctors. I'm just researching this information having just bought a unit, but if you are persistant, you should be able to find the software link. Any micro USB to USB connector should work to connect to the computer. Merry Christmas and good luck! 12/25/09 by electro1
SOURCE: Need instruction manual
Homedics makes several units that are virtually identical to the Walgreen counterparts. Why not try the Homedics web site? It has a support section. Be sure to list your model number as there are several wrist cuff models. If the web site doesn't help, either call Homedics or try a web search by listing your model number followed by 'manual'. I would have tried to find the manual for you but I don't know the model number. Good luck.
SOURCE: We don't the manual for our model #BPA-440WGN and
We're having consistently high readings with ours, too. We've compared it with as many as two other units at various test sessions.
From the manual:
All digital blood pressure monitors require recalibration in order to ensure continued accuracy.
This monitor does not require recalibration for 2 years under normal usage conditions (approx 3x/day), at which time your monitor will display "CA." The unit should also be recalibrated if the monitor sustains damage due to blunt force (such as dropping) or exposure to fluids or extreme hot or cold temperature changes.
To send monitor for recalibration, please ship to the address below with check or money order in the amount of $10 payable to HoMedics, Inc., for recalibration service, shipping and handling:
HoMedics Recalibration Service Center
Post Office Box 7050
Walled Lake, MI 48390
Allow up to 3 weeks for return of product. For additional information, contact HoMedics Consumer Relations at 1-800-466-3342.
So, do we spend $10 plus postage and wait 3 weeks or more...or do we use the $10 toward a new one immediately at a Walgreen's a half-mile away? It's a nice unit and works well otherwise, so it's a quandry. I hate to toss it. Good luck.
Mark in Oklahoma
SOURCE: Homedics BPA-110-2AU blood pressure monitor.
This can be due to failure of the pump. If there is indication for the start of the pump , then the pump motor must be initiated . If not you will need to trace the power supply to the motor if not present the driver can be faulty. If present the motor drive is jammed or failed.
