HP LaserJet 4L Printer Logo
Question about HP LaserJet 4L Printer
It's al black horizontal lines/smudges over the printed page. How to cean this?
Posted by Hans Zonne on
darinthal
    Novelist:
  • HP Expert
  • 181 Answers
Black Horizontal Lines are normally caused by a Light Burnt Drum.
The drum in built into the toner cartridge for this machine so replacing the cartridge will fix the problem.
Posted on Jan 16, 2015
Testimonial: "thanks"
5 Related Answers
Anonymous
SOURCE: hp laserjet 1000 prints horizontal lines
software download
Posted on Apr 18, 2008
Anonymous
  • 300 Answers
SOURCE: a pink line is on every page printed
This is a very common problem with this model printer, it is caused by toner on the scanner mirrors. You need to clean the scanner assembly unfortunately it isn't very easy to dissemble the printer to get to it.
Posted on Aug 12, 2008
checkitright
CheckitRight
  • 1363 Answers
SOURCE: printer prints white thick blank lines
1- black lines are from the drum: it has burnt out on that particular spot and rotates
2- the white horizontal gap space if it is not you skipping space is also from the drum
3-the white Vertical is most likely from the developper (unit that has the toner and is against the drum, look at the roller it should be solid black, maybe there is something on it : hair paper etc....
Posted on Aug 26, 2008
The Machine
Dean Joly
  • 788 Answers
SOURCE: lines across printed pages
Does the line repeat, if so tell me what the distance it between repititions. I need the EXACT measurment in millimeters preferably but inches will do.
Posted on Oct 24, 2008
Anonymous
  • 135 Answers
SOURCE: hp laserjet 4 plus - keep getting a horizontal black line
yes you have to catch printer making the line and then as a page is being printed you need to open door to stop paper after green cylinder(drum) as it is entering fuser, then you need to remove paper from printer without pulling through the fuser, if you see the line then rub your finger across line up and down page, if it smears at all then its the cartridge if not then the fuser
Posted on Apr 27, 2009
2answers
Smudged horizontal lines
Try cleaning your rollers, it worked for me. I hope this helps.
Canon Printer - Pixma 5000 Trying to print out pages of text. The text is coming out with a line printing normally - then a block of text / lines missing completely - then tops of line or bottom of line...
pull out the black cartridge then get a tissue paper try pressing the nozzle again the tissue paper but not so hard then release look for the straight line that appear on the tissue paper if it is not change it
3helpful
3 black smudge horizontal lines on prints
Your brother can send faxes without printing the pages try your computer just you should download the driver.
You can download the driver from this link: " http://download.cnet.com/Brother-MFC-8220-USB/3000-2118_4-65318.html ".
About the lines which appear on the print, you will have to buy a Drum unit for your Brother 575, because the drum cleaning blade has quit working and there is no other way to fix this only by putting a new drum unit.
note:
the drum unit is different from the toner cartridge, but if you search good you can find them together for lower price.
Please rate me
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Printing black smudges across the page at 10 cm intervals
Most likely cause by the drum unit. Replace drum or upgrade printer.
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Color lines/dashes at top and middle of page when printing.
Amand321,
Your problem lies with the fact that you manually refilled your cartridges. This is not recommended by any technician I know and your solution is in the replacement of all your cartridges with genuine brother consumables. It is going to be expencive, but it is the only real solution.
Gremlin11
Black smudgy streak in middle of printed page
if you need any parts for that machine a have 4of them
Thank You,
Mikey
Clive
Clive
Ben Johnson
