Different paper. Adjusting tray paper size.
Lexmark issued a TSB (Technical Service Bulletin) back in October for several different printers, including yours, involving a firmware update. http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_MS310#1
Have you applied this update yet?
SOURCE: Lexmark E232 - Tray-1 Paper Problem
Have the same problem after 1,500 pages! This was Lexmark's solution (and it worked)...
Take the paperfeed tray out and you will see a red lever , press it
downwards and you will see the paperfeed rollers coming down , you need to
pull the rubber tyres off those rollers and place them inside out over
them and then try printing any document. Check the paper weight and
the paper type you need to use 20 pounds regular paper and try runnning a
can of compressed air inside the machine.
If rubber tyres on the paper feed rollers are totally worned out you
need to replace the feed rollers.
SOURCE: feeds paper crooked
Lexmark printers are hyper sensitive to dust..It might be causing this problem...Take a cotton swab dip it in alcohol and press it against the roller whilw pressing the paper feed button....
If this doesn't work you should try a longer procedure...Remember you have to look real hard..
It's possible that the paper may be running into a foreign object and
not feeding in at all. A foreign object could also cause the paper to
stall, or even feed-in crooked. Remove all the paper and use a
flashlight to look carefully into the paper feed-in area. Look for a
pen, pencil, push pin, paper clip, candy, etc. If you can't see
anything, then actually pick your printer up and turn it so the paper
opening is facing down and shake it a little, side to side. Your trying
to dislodge anything that might be stuck in the paper entrance area. If
nothing falls out, then turn it back over and use the flashlight to
once again look inside that area. Sometimes you'll see an object that
may have moved over into view while you were shaking the printer. Any
foreign object might block the paper from actually being able to move
forward, so then the printer thinks there is no paper installed. You
may have to even remove the Top Cover to be able to get a better view
of that paper feed area. Unfortunatly, just removing that cover is not
always that easy, especially on the newer printers. You may need a
Service Manual for reference, disassembly and troubleshooting. I have
not checked, but you can normally find Service Manuals for most
printers, at www.2manuals.com (most Service Manuals can usually be
downloaded for around $10 +/- ). Even if there is not a foreign object
stuck in that area, with the top cover off, you might just possibly see
what the problem is and even be able to correct it..
SOURCE: Lexmark X73 print/paper problem
Same problem here. Went thru a few tests with Lexmark but didnt help. They next said it would be best to get new one since repair cost would be higher. Thru front door I do see a spring that moves freely. That must be broke. After their help they sent email for 20% off.
SOURCE: Lexmarkx73 Won't feed paper through while printing
my lexmark x73 makes a clicking sound while printing and paper does not feed correctly
SOURCE: paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
tuval.
[email protected]
hope fore replay.... :)
