Question about Frymaster Dean Kitchen Appliances - Others
Can anybody tell me what's wrong with this? Any suggestions please and thank you.
Posted by Sylvester on
starztruck4u
    New Friend:
  • 77 Answers
The burner or the burner venturi is clogged. The burners are held in place with 2 bolts at the top and you need a 1/2 inch wrench. Remove the bolts and lift the burners off the brass orifices. Make sure all the holes are clear. If they are clogged they need to be drilled out. You should not have yellow in the flames in the burner tube.... kinda looks like the are sooting. This causes flames to come out the bottom of the burners.
Posted on Jan 27, 2015
My sdmo 1000 generator has no spark at the spark plug can anybody tell what is wrong and where I can get the parts to repair it regards Eric
If it has a ICU that would likely be the cause, check with the dealer of this product for parts. We are not a parts dealer for any product and can only suggest a likely source.
Oct 11, 2016 | Electrical Supplies
Ford Fiesta 1.2LX Zetec Engine model 1999...Passenger Side Electric Window suddenly stopped working, although the Driver's Side still works...could anybody tell me if they know what is wrong with
either window button or motor gone is ther any noises at all from the door cards like a thumping noise or is it dead all together but sounds like motor to me as a fuse would knock both sides off
Aug 17, 2012 | Ford Fiesta Cars & Trucks
Started macine, it banged and then smelled, now out of action
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Also as a help for the future it helps us help you if you tell us the make and model of your washer, please;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 26, 2011 | Washing Machines
A mate of mines imported 125 wont start up with the electric, but WILL start up first time on the kick start. I dont think its the battery (although i could be totally wrong) as he rides it to work...
Problem might be the battery and the reason behind it is the starter is taking more power then the battery has and short changes the ignition which requires a minimum of 10 volts to work.
Dec 29, 2010 | 1982 Yamaha XZ 550
In need a help desperately
have you put diesel in the tanmk instead of petrol ,all the symptoms point to it
Dec 21, 2009 | 1997 GMC Sierra
Can anybody tell me whats wrong i keep getting scanner error
try uninstall your software for your scanner and reinstall it after restarting your PC
Oct 08, 2009 | Office Equipment & Supplies
Help Me about vbagx 1.20 keygen
280719493269931220713493869941 i hope it works...
Jul 03, 2009 | Nokia N-Gage QD Console
Forgot HDD password? please help?
Boot the computer in safe mode. You will be able to go in and reset your password. and once you are running you can always install your normal password. Depending on the operationg system usually F10 or F2 or on some the DEL key will get you into the safe mode.. Good Luck easy do once you are in safe mode....
Mar 23, 2009 | Acer TravelMate 2480 Notebook
Fan Error
Please contact the supplier for support under warranty.
If not under warranty, do check the power for the fan, after opening the outer case
Please disconnect the main power before opening :)
Try to tell me.... whether my suggestion was useful???
Bye
Have a nice day.
Feb 06, 2008 | NEC MultiSync VT540G Multimedia Projector
Open Questions:
Kitchen Appliances - Others Logo
Top Frymaster Dean Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Paul Carew
Lawrence Oravetz
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
