Question about Frymaster Dean Kitchen Appliances - Others
I'm not sure of the name of the parts, when the fryer is turned on flames come out of the bottom of the three front pillars? I'm not sure how to stop the problem. I've removed them and cleaned out soft deposits but it still kicks out flames, any suggestions would be appreciated thank you.
Posted by Sly Hanna on
starztruck4u
    New Friend:
  • 77 Answers
Drill out all the small holes on the burners(pillars). Remove them by taking out the two bolts at the top of each burner.
Posted on Jan 27, 2015
5 Related Answers
kebah
Angel Joseph Jr.
  • 684 Answers
SOURCE: pitco deep fryer flames coming out the fryer
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
Posted on Sep 13, 2011
Capt Rick
  • 81 Answers
SOURCE: DEAN SR142GPS Flame Issue
A gas valve is actually 2 valves in one. The first is your pilot valve, when the pilot is lit, the flame heats a thermocouple or thermopile & that heat produces a millivolt signal that is sent to main gas valve( second part) & tells it that pilot is established and to open to allow main burners to light. The 3 "little flames" were coming from the orfices on the burner manifold. If you are absolutely sure you put the gas valve back in the same direction as it came out (arrow on bottom of valve pointing to the fryer/burners) & any springs or adjustment screws were not mucked with, then there is a malfunction in the gas valve. It needs to be replaced.
Posted on Jul 25, 2009
Anonymous
  • 75 Answers
SOURCE: gf 40 frymaster fryer
Hi, I am suposing that this fryer has worked good in this location before. If not, check to make sure it is set up right for your gas supply. (LP-Nat) There is something wrong with the gas - air flow in your unit. Look for obvious things first like exhaust being blocked, Flame dancing out side of fire area, Pilot too small, Build up of debris in fire box. The pilot should be able to be adjusted at the gas valve if it is too small. I believe you problem could be taken care of best with a good cleaning of the burner, fire box and pilot assemble. Make sure that all burner holes are clean especially around the pilot light. Check for oily debris inside the fire box to make sure its not leaking into the fire area. If you are unable to do this yourself, contact some one either in the restaurant equipment service business or heating and air conditioning business. Hope I have helped you. kstfas NOTE: If this answer does not rate at least 4 marks, (almost there) please do not rate. Thank You.
Posted on Sep 27, 2007
Anonymous
SOURCE: Can you remove the bucket (part that holds the oil) on a CF153 ?
as Kachbibi1 suggested, I took the deep fryer apart.
I guess ,if you, REALLY wanted to take it out ,you can. I would NOT suggest doing so.
it is connected and bolted to all the wires and coils to heat the fryer.
My thoughts are, clean well, right away! if we take it out to clean, we will have to replace it right away ..
thank you for the suggestion Kachbibi1...trying that helped me know I cant be lazy : )
Posted on Feb 20, 2009
Anonymous
  • 125 Answers
SOURCE: How to clean the bottom of the fryer?
Hi there. Probably your best bet would be to prop the rear legs up a little, to tilt it forward, and use a garden hose, and flush everything into a bucket in front of the drain. You may need warm water, to loosen the debris, or you could fill it with water, hook up the gas, and boil it, does a fine job of cleaning.
Hope that helps, and thank you.
Posted on Feb 21, 2009
My lpg fryer IFS40 burns yellow flame and on the recent inspection tech supposedly found corroded heat exchanger. The fryer is only half a year old and still under warranty but the imperial only offer
The heat exchanger might be a result of the yellow flame but not the cause of it burning yellow. I would guess it is the amount of air being mixed with the gas. Most burners have a slotted metal air mixture ring on the front of the burner near the brass orfice, you are calling a jet. There is a locking screw to release the ring so it can turn to adjust the amount of air being mixed with the gas. If this doesn't fix the yellow flame it could be a gas pressure problem that could be the external regular in the gas line. Not sure if you are talking about the pilot flame or the burner flame or both? A tech should know how to adjust the air mixture.
Oct 15, 2014 | Imperial IFS40 Deep Fryer
I have a picto fryer and when i turn of the t-stat knob the main burners turn off but there is a small flame at the orifice tip.
If that small flame does not go out, it sounds like there is gas passing around the valve core of the gas valve. Regressing the core will stop this from happening.
Mar 08, 2014 | Pitco Frialator SG18S Deep Fryer
Help flames front of fryer
Hi there.
Try to check and clean if needed the fire tubes, soot may have build up inside blocking the flame path. Soot build up on fire tubes and burners are caused primarily by low gas pressure, assuming that the orifice size are correct with respect to the type of gas used.
Regards.
Sep 03, 2013 | American Range Kitchen Appliances - Others
Pitco deep fryer flames coming out the fryer
Hi there.
Regards.
Sep 12, 2011 | Pitco Frialator SG14 Deep Fryer
Need to know where to light pilot
Normally, it's under the fryer, inside the door...The issue almost always is you have to press the button down long enough for the sensor to tell the fryer to light....There are 3 or 4 burners in the bottom of the frypot on top and under the fryer is the pilot to light these all up...Look for the gas valve, turn the gas valve to pilot, and press and hold it down, put flame to pilot and release button when flame is self standing... Then turn to on position. If you have other issues, call the Vulcan company themselves, and they will help you further.... Susan Restaurant Equipment Outlet, Cinc, Oh www.restaurantequipmentinc.com
Aug 20, 2011 | Vulcan EF3 Deep Fryer
Flame not going into heat tubes
Make sure the regulator assembly on the gas valve is for propane. Sounds like the gas pressure is too low and the flames aren't going into the burner tubes. Make sure they didn't install an appliance regulator on the back of the fryer. This is not needed as the fryer has a regulator on the gas valve. You can unscrew the cap on the regulator assembly and turn the plastic screw inside all the way in. DO not turn with alot of force. Easy does it.
Tom
Jul 23, 2010 | Imperial IFS40 Deep Fryer
Pilot does not turn on. Fryer was in use n working perfectly. We turned pilot off cause fryer was not gonna be in use. so now pilot does not turn on.
Make sure the high limit isnt tripped. There is a red button down next to the thermostat that you push to reset the high limit. If it will not light after that it is probably a bad thermocouple - This is the sensor located in the pilot flame.
Make sure it is well positioned in the pilot flame. If not adjust it into the flame, if so replace it. They are generally available at your local hardware store because they are also used in water heaters and home furnaces. They are pretty cheap and fairly easy to change. It ususally requires that you remove one or two of the main burners for easy access. Empty the grease first just to be safe. Remove the nut from the top of the drain valve handle and remove the handle. Look to the top of the main burner or burners in front of the pilot and there are two bolts on each burner that need to be loosened (not removed) and then lift the burner to remove the bolts from the slots and pull the burner down and out. Remove and replace the sensor (should be fairly straight forward), Replace the burners and valve handle, refill with grease, and try to light it again.
Jun 08, 2010 | Cecilware EFS-40 Deep Fryer
I got problem with my cecilware gas deep fryer fms 40, i was able to turn on the pilot, then i turn it to full on possition, but the fire will go out when i was trying to adjust the thermostat, please...
Make sure the flame is staying on the burner and not lifting away from any sensors in the flame. You may need to adjust the air bands on the burners to get the flame to stay down. Also make sure the vent in the back is free of blockage.
Feb 13, 2010 | Cecilware FMS-40 Deep Fryer
Hi need sper part for pitco fryer flame failure valve model no 14
It sounds like you are not recieving a heat feedback signal. It may be as simple as cleaning your flame sensor, using a emery cloth/ scotchbright. Be sure that all gas is turned to the on positions. Also that any safty high limits are closed / reset.
Scoota
Dec 12, 2008 | Pitco Frialator SG14 Deep Fryer
Jul 24, 2008 | Kitchen Appliances - Others
Open Questions:
Kitchen Appliances - Others Logo
Top Frymaster Dean Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Paul Carew
Lawrence Oravetz
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
