Question about Electrolux Freezers
How to set temperature on built-in freezer that is not part of a fridge
All answers relate to fridge freezers. We are in a retirement flat and the freezer, built-in under worktop, is quite separate from the fridge. The freezer is so frozen up it is difficult to open the drawers. What to do?
Posted by Mrs D M Walker on
theratdog
    New Friend:
  • 5 Answers
Well start by defrosting it.
Empty out the contents and put the contents in a cooler and then switch it off. You may need to switch it off at the electrical control panel by flipping the circuit breaker.
Once you have turned it off, use hot water to help remove the ice. Have plenty of old towels around for this as water will get spilled on the floor. Once it is empty and the ice removed you may discover a temperature control switch, but if not, just be prepared to repeat the exercise every 6 months or so. In any case it is not a good idea to run the freezer when it is iced up. Once it is emptied and cleared out switch it back on and wait 10 minutes before adding your stuff back. Sometimes freezers will heat up a bit before they cool down. Once you verify its getting cold, put your food back in it. Good luck.....RD
Posted on Jan 14, 2015
Hi i have a wirlpool fridge the freezer and fridge works fine but it seems the motor keep on running and dont switch off or is it the fan that is running please help
Hello Sandra;
My name is Peter. I am a retired field service refrigeration technician.
You just have a simple operational and maintenance issue.
Neither your compressor or fans should run continuously.
First, you need to clean your condensing coil. You did not provide a model number so you either have a flat cooling coil in the front bottom, or a canister type in the back right hand side. This coil dissipates the heat. If it is plugged up your compressor and fans will run trying to keep up with the unit temperature settings. This can make a difference as much as 40 degrees. The toe plate, bottom front is either held in place with a screw on each end. If no screws, there is a clip on each end. Just pull and it will pop out.
Second, You only have only one cooling source and that is your freezer. The freezer will try to satisfy itself first before the fresh food section. If you set the temperature controls beyond the unit design settings your compressor and fans will keep running. Set your freezer to -2 or +2 Deg. F., and set your fresh food section to 35-40 Deg. F.
Third, Check your door gaskets. make sure there are no gaps.
Dec 21, 2014 | Whirlpool Replacement Refrigerator...
Good day. My Samsung fridge/freezer SR-S22FTFB runs normal for the first few hours when been switched on, both fridge and freezer temperatures were set for (- 18 and 2), both fans are running and when
Hello Danie;
The normal setting for a freezer is -2 to +2 degrees F., and the normal setting for the fresh food section is +35 to +40 degrees F.
You only have one source of cooling and that is your freezer. With the settings that you have, you are asking your unit to do what it is not designed to do.
The ice maker is struggling because if it is a cast steel ice cube mold, the heater beneath it is not designed for the current to break the ice cubes free @ -18 degrees F., or if you have a plastic flex ice cube mold it is too ridged to flex enough to break the ice cubes free. Normally your ice maker should dump 8-10 times in a 24 hour period.
A note on food storage. Make sure you do not overload your freezer of fresh food section to the point where food product extends beyond the edge of the shelves.
Nov 17, 2014 | Samsung Freezers
I have a freezer bosch log/xx model dc125e12raw5r600 tempretureis only -5 is this normal
Hello;
The ideal temperature range for a freezer is -2/+2 degrees F. This temperature range can very depending how full the freezer is. If your freezer is jam packed -5 degrees is good. If it is half full, +2 degrees F. is a good setting.
Too high of a setting such as -20 degree F. will cause freezer burn (bone dry your food).
Your compressor will kick in and cycle until it reaches the temperature setting. You can save on your electrical bills based on your evaluation of the necessary temperature setting.
Oct 19, 2014 | Bosch Freezers
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
I am just trying to find out what are the recommended settings for a 8.8 cu. ft. energy star rated Frigidaire chest freezer.
I would suggest getting a fridge/freezer thermometer and use that to set the temperature. They are marked with the recommended temperatures. Also many times the setting on the nob in the freezer are not very consistent so it is better to actually set the temperature by turning the knob up or down to reach the desired temp on the thermometer
Sep 18, 2010 | Frigidaire Freezer 8.8 cu. ft. Chest...
Electrolux fridge freezer, Motor never turns off. replaced thermostat, still motor keeps running. The back, top half of fridge freezes over but the temperature remains cool?
dear sir/madam
i think this is thermostat setting problem please make sure freezer,s thermostat nobe (nidle) is in correct position .then see thermostat temperature settings . may be thermostat is not controlling to compressor motor that why it,s running continuously.
hope answer the question,
thank you
please vote!
Sep 02, 2010 | Electrolux Freezers
How do i set the temperature on daewoo fr661nt fridge freezer as the freezer is not working . I have not got a maual so any help will be welcome.
Sir my fridge FR661NT freezer working But refrigerator not working anything setting problem ????
Sep 13, 2009 | Freezers
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Sep 23, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge freezer
Check your settings for the temperature controls. Freezer may be set to warm (IE #1) set it mid point. Also set the refrigerator at mid point and go from there to adjust each to maintain the temperature balances.
May 31, 2008 | Freezers
Freezers Logo
119 people viewed this question
Top Electrolux Freezers Experts
Dennis Boxerman
washington munene
Level 1 Expert
ray gallant
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
