Question about Samsung Office Equipment & Supplies
My Samsung colour xpression keep telling this message "The door is open" and doesn't let me to copy.
Posted by Saad Kasim on
Mohan Kumar
    Sniper:
  • 98 Answers
EPM or You can login to admin page of Printer and check more details about the error alert in homepage. Or use samsung SPDS to get more information.
SPDS Android Apps on Google Play
Posted on Jan 20, 2015
sahoo_sanjay
    Master:
  • Samsung Master
  • 553 Answers
Dear
You have not mentioned the model. However you can download the SAMSUNG EASY PRINTER MANAGER which can show which door is opened. The door has a leaver which close the switch inside the printer to acknowledge the door is closed, either the lever broken or mis-aligned. You can check it with a insulated plastic knife pushing the sensor switch.
hope the above may get you some idea.
thanks.
Posted on Jan 14, 2015
I HAVE A SAMSUNG PRINTER SCX-4623 THE MESSAGE KEEPS ON SAYING DOOR OPEN CLOSE DOOR , TRIED EVERYTHING BUT NOTHING WORKS
Dear
The front door right side there is a lever found when it is opened the lever should close the micro switch inside and the door is locked with another short lock (near the long lever). If door lock broken then the micro switch push the lever and door not closed.
the basic problem with the micro switch and related mechanical alignment.
Thanks.
Feb 26, 2015 | Samsung SCX 4623F - Multifunction fax /...
How do i delete facebook messages from my LG Xpression (AT&T)
If you have the Facebook messenger app downloaded on to you phone, you need to uninstall it. OR you could change it on your facebook account settings
Jul 14, 2013 | LG Cell Phones
My Lg Xpression will not delete 1 message and keeps saying empty content when touched on
Its an phone memory file system crash.. No need to worry. backup all contents except messages. There will be a option to restore factory settings in your phone. Reset it.. The message will be erased automatically
Dec 20, 2012 | Cell Phones
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3185
Hi
Have you checked the cartridges access door?
If so,try disconnecting the printer and leaving it for a long period [like 1hr] before connecting again.
Feb 28, 2012 | Samsung CLX3185 AllInOne Laser Printer
I have a 5 month old samsung steam front loader that gives an error message of d5 . What does it mean and how do I fix it
the door is not sensing that it is closed. open it and re close the door again, make sure it is closed all the way, if it is and it still gives you this error, unplugg the machine, close and open the door again, and plug it back in and try again. if this doesn't work, you'll need to have a repairman take a look at your washer.
Mar 01, 2011 | Samsung WF448AAW 4.5 cu. ft. Front Load...
Cover open message and there are no covers open
On Many of these printers, when you recieve this message chances are you either have a "BENT" limit switch sensor or the Tap on the Cover is "Broken or Broke off",
First Step open each cover and close them again sometimes the limit switch isn't being hit correctly by the door Tab
Second- as you open the covers their are tabs that must hit these sensors- make sure their not broken or bent.
Start their and tell me if these resolves the problem chance are the tabs are not hitting the switches correctly and not telling the samsung printer that the covers are closed.
Apr 24, 2009 | Office Equipment & Supplies
Samsung P801.washer....Error Message " ED" WHY??
"ED" is a door open error. try Closing the door properly or else there might be jam at the door.
Dec 12, 2008 | Samsung WF337AA Front Load Washer
Sony Mavica MCD250 -"Door Open" error message
have that opened up in a service center and tell them that you dropped it. they will tell you that the sensor is busted. that will have to be replaced. hope this helps.
fixya!
Jan 29, 2008 | Sony Mavica MVC-CD250 Digital Camera
Samsung CLP-500 cutting off print
The duplexer is bad or needs to be realigned, shake up the cyn color. it mostly likely low.
Dec 06, 2007 | Samsung CLP-500 Laser Printer
104 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
