Televison & Video Logo
Sarah Posted on Jan 14, 2015
I have an alba tele in my children's room, we bought it a year ago. We have missed place the remote control ? So now can't press play on the DVD, is there anyway to get a replacement? My email is- sa
I have an alba tele in my children's room, we bought it a year ago. We have missed place the remote control ? So now can't press play on the DVD, is there anyway to get a replacement? My email is- [email protected]
tfyoder1
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Jan 14, 2015
tfyoder1
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
2753
Points
21
Purchase a Logitec Harmony remote. When you set it up, the software asks for the device you intend to control. Enter in your make, and model number. After the remote setup is complete, you should be able to control it.
I would check on the logitec website before you purchase to make sure your device is supported before making the purchase. But they support just about anything under the sun.
5 Related Answers
Anonymous
  • Posted on Dec 09, 2008
SOURCE: tv and dvd remote controls interfere with each other
found out that signals from both remotes were on same waveband
moved dvd player tp differnet tv in diferent room and bought new dvd player to couple with LG flat screen
Not a technical solution bit did the trick
Ray
byziol
byziol
  • 18 Answers
  • Posted on Dec 29, 2008
SOURCE: Astar 27" TFT LCD TV, Model LTV-2701
Universal Philips Remote control will work setup code 007
Anonymous
  • 814 Answers
  • Posted on May 17, 2009
SOURCE: Trying to get a remote that was missing when purchased TV/DVD
if the unit has a warranty try to get target to give you the missing part.This product is their house brand. Hope this helps you with our problem.
Chi Chu
  • 8457 Answers
  • Posted on Dec 11, 2009
SOURCE: Replacement Remote for Ventuter PLV31220S1 TV/DVD Combo
Try website 1-800-Remotes Factory original.For an original or very close to it.
Testimonial: "PERFECT. Found it through your answer. Thank you again so much for your help. This is a brand new TV to us and the remote got tossed by accident."
Azrael SRL
  • 11800 Answers
  • Posted on Jan 30, 2011
SOURCE: Hicon HDVD22 (bought Jun 2007)
Either it's a bad soldering (it makes contact only when the metal shrinks due to the cold) or the IR diode is dying. Take the remote apart and inspect all the solderings with a magnifying lens - redo all dubious ones.If this doesn't work then replace the IR diode with one taken from another dead remote.
Your player is a low volume, obscure model, no universal remote will have the codes for it. You will need a remote that can learn the command codes from the old one, one like
http://www.calgarysatellite.ca/X10-5-in-1-Universal-Learning-Remote-UR73A-p/x10-5-in-1-universal-remote.htm
I set a parental control password on my alba lcd32880hdf 2 years ago and can't remember what it is. Can I reset it?
When you said this: They said: turn on the DVD player. Hit "set-up". Scroll down to the "lock" icon. Scroll over to "Rating". Scroll over to unlock. Enter 0000. Click on Ok. Enter 0000 again, click Ok again. Menu should read unlock. Voila!, is that dvd on the tv or a normal dvd player
Have alba 17" tv/dvd/ipod combo.have
try contacting the manufacturer or the retailer where you bought it. otherwise, buy a universal remote control like the logitech harmony, wich is programmable to the extreme
2helpful
I bought an Alba CDVB4 and the remote isn't right
Hi
Not sure if you found the problem for this, but I had the same problem and couldn't find any reference to this except your question so thought I would put up an answer in case it can help you or anyone else.
Aparently, Alba have got hold of the codes that Toshiba use for their remote controls, so if you have a Toshiba telly an Alba product like this won't work. The only solution being to return it and get a different make.
I returned mine twice for a straight exchange thinking it was just a manufacture fault before I found this out. I then exchanged it for a Bush set top box - only a fiver more - and it now works PERFECT!
I hope this helps some.
Zoe
Tv and dvd remote controls interfere with each other
Ray
2helpful
2answers
Child lock
I also have a km0544 tv and the child lock is on however I lost the reote control for it some time ago when re-locating house. Do you have suggestions?.- Steve
How do you put on a dvd?!
i take it all set up the dvd to tv.?
turn on the dvd player with the remote .
press open on the remote
insert the disc dvd out of the box
close tray
press play to watch dvd
when finished
press open take out disc and close disc tray and turn off dvd player .
riz.
Dvd-r problems
Unplug your AC power cord for a minimum of 30 seconds to clear the RAM. The RAM is used solely for dvd class history, and clearing this should solve your issue. If you want to convert your player to region free, which will allow you to play ANY dvd: 1 Disconnect your player from its power source for thirty seconds 2) Reconnect your player to its power source 3) Press the Power On button on your remote control 4) Press the Enter button on your remote control 5) Press the 8 button on your remote control 6 Press the 4 button on your remote control 7) Press the 2 button on your remote control 8) Press the 6 button on your remote control 9) Press the 9 button on your remote control 10)Press the Enter button on your remote control 11)Your player should now place itself in Standby mode 12)Press the Power On button on your remote control A word of caution if your convert your player is that disc eject issues may arise in which you will have to eject from the unit, or toggle your power switch on/off.....good luck my friend.
Top Alba Televison & Video Experts
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
NOEL
NOEL
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
