Top Expert:
Sony Master
Re:
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Electro help
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.
How many times do this standby light blinks at a time of switch on? These blinks are fault indications. From the number of these blinks, you can get an idea about the faulty circuit section inside it. Count it. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Count the number of blinks occur at one time switch ON. These blinks are fault indications. After counting it, check this link for more details. There are details about Sony blinking codes. Search the site by brand name and model number to your TV in its search box.
Hello
Vertical IC inside your Sony TV has damaged [shorted]. Four blinks of standby light denotes it. The number of blinks of standbylight in Sony denotes some fault, and can be determine according the the continueous blinks. In your case, the standby light will blink four times, then stop for a while and will continue to blink four times and so on. Vertical output IC should be replaced with same type and number. If you are aware in electronics and have tools, you yourself can do the work.
If you wants anymore assistance, feel free to get me by Fixya.
Thanks for using Fixya.
I HV A PROBLEM WITH SONY-KV-HA21M80 TV. WHEN THE SWITCH ON POWER ON AND GETTING OFF. FRONT LED IS BLINKING 4 TIMES. WHAT COULD BE THE PROBLEM. PLS HELP ME ON THIS.
Thanks for reply and nice to know that you are in Algeria.
You need to pay attention on Screen Volts as wrong G2 (screen volts) can be cause of 4 times blinks as you already replaced vertical out put IC.
You can download service manual of KV-HA21M80 from HERE and it is free. Download all 3 parts of file and use WinRaR to unzip it. You will have complete manual in pdf format.
