Partition the hard disk without formatting
Repair your os on your laptop and open system tools click on divise menagement
after Right click on free space select new partion give numaricle no. click ok.
whenever you repartition a drive all the data is lost in those partitions
a quick way to get rid of rundll32 error is to do a system restore using safe mode, which will restore your system configuration to a date when your system was working fine without rundll32 error, it is possible if you remember the date on which your system was working fine
when the system starts at the blue dell logo start tapping the F8 key and when it gives you the option to use safe mode select it and then
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
here it will show you in bold the dates to which you can restore your system back to, select the date and continue, but restoring a system back in date will make you loose any new settings done to the system or any new software installed to the system.
If you think the above info was helpfull please do rate me
Regards
Ltoso
Windows 7 will format an external partition to FAT32, as long as it's 32GB or less. "Control Panel -> System and Security -> Administrative Options". Right click on "Computer Management", select "Run as an Administrator", double-click on "Storage" then "Disk Management", the right click on your external drive. Select "Shrink Volume", shrink it by 32GB or less, then right click on unallocated space, select format, and "FAT32" will show up as an option during the format wizard.
This is a way to create a small bit of space on an external hard drive for copying some files from Mac OS's to Windows.
Um, do you have a rundll 32 error? or do you want to know how to partition a hard disk without formatting? The old Partition Magic software was always my favorite for partitioning (re-sizing, etc.) without formatting. Sometimes you just gotta format though. ...tell more...
