Just trying to remove all remote start and stop wiring there is no need for that on the quad anymore
It is possible. What you do is eliminate the unit and all the wires and wire the engine direst to the kill switch You need power to the coil from the kill switch, that's all. the second wire is ground, or depending on the design the kill circuit may be the ground side of the circuit. in any case the wire on the coil is positive power. you should find it fairly simple to eliminate the remote system if you think of basic requirements for the machine to run. Most remotes simply cut the power off. You will definitely need to connect 2 of the wires together. Judging from your pic I would cut all the wires and connect same color wires together.
