Question about Marantz Audio Players & Recorders
How do i change a power supply
Marantz av sorround receiver sr5004
Posted by tshepo on
ismailkostak
    New Friend:
  • 13 Answers
A hi-fi receiver typically does not have a power supply that you can simply remove the broken one and plug the new one in. They are not designed like desktop computers. Try to locate and fix the broken component first.
Posted on Jan 14, 2015
2answers
My sr5004 marantz receiver has gone into standby with the indicator is blinking how do i get ride of it
If the red led is blinking fast (8x/second) the power supply is likely damaged and the unit will need to be serviced. If blinking slow, the most likely cause would be a shorted speaker connection. To help find the cause, unplug everything including the power and speakers. Connect only the power and try to turn the unit on. If the light doesn't blink, you know you have a shorted connection. Power off and connect the inputs and then power back on. If the light is not blinking, you know the problem is with an output connection. Just find the bad connection by process of elimination.
Manual: http://us.marantz.com/DocumentMaster/US/SR6004-5004_U_EN.pdf
2answers
My sr5004 marantz is in standby with the indicator is blinking on the front how do i get ride of it
Power the unit down and remove all cables. If it still blinks when you power back on, you probably have a PS failure. I could not locate any fuses or circuit breakers on mine and had to return for service. There is a factory reset that can be performed by pressing and holding the surround mode and clear buttons on the front panel at the same time for 3 seconds.
Marantz SR5004 shuts off after a second or less
It's going into safe mode check the power supply
5helpful
My marantz sr5004 is flashing the standby light and wont switch on
Switch off the unit. Then hold down Sorround, Exit, Memory & Clear buttons all together and then switch on the power. This should work.
What is the Best way to connect a Wii to the Marantz SR5004
the best soution is to connect them.hope this helps.kind regards,KJ
6helpful
Marantz SR5004: display says 7.1 CH input source direct. I can't change the sources at all. TV is working but no sound. I think my kids hit a few buttons, but I can't reset it. Thanks
Look on your remote. There is a button top right that says 7.1. Hit it. Reselect input and surround and you should be good to go.
2helpful
New tv, new marantz sr5004, hdmi cable- no sound out of speakers
To really help you would require a bit more detail. HDMI is the video part of the signal - the audio part may require additional cables. Also, source material may play a role. I'd start by seeing if you have some audio outputs from whatever your source is and connecting those to the Marantz. Beyond that, I'd need more info to be sure I was giving decent advice.
4helpful
3answers
SR5004 amp on standby mode (red light blinking twice a second) / cant get it out of stand by mode
I am having the same issue as well. If you press "clear" "exit" and "surround mode" all at the same time, it will come back on. It seems to be an overheating issue. If you put a fan on it, it helps, but does not fix permanently. Anyone have any ideas for a permanent fix?
10helpful
2answers
Need to give a FULL RESET in a MARANTZ SR5004 RECEIVER
NEED TO KNOW HOW TO GIVE A FULL RESET ON THIS MARANTZ SR5004 RECEIVER...MANY TKS
This unit is turned on, press and hold the SURR.
MODE + CLEAR buttons simultaneously for 3
seconds or more
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
