As it spins very slowly back and forth it also makes the grinding squeeking noise.
Made sure nothing stuck in drum. Also made sure everything is clean.
Posted by Robert Cottrell on
nomess
  • 343 Answers
Hi Robert.
What you describe sound like a distorted drum and/or collapsed bearings. The grinding noise is typical of bearings which are worn out, and the squeaking can come from the drum rubbing on the door seal.
Check if the inner drum is loose and flops up and down. Also spin the drum by hand and see if it's touching the rubber door seal anywhere. If it spins freely but make a growling noise your bearings need to be replaced..
Neither of these situations are good. A serviceman is probably required to know for sure.
Good luck.
Nomess
Check that drum (2nd below) is not rubbing on this door seal
As it spins very slowly back and forth it also mak - 25366879-qe21trzqur2fp0qsdhi0qucy-5-0.jpeg
Drum should rotate quietly and smoothly
Posted on Jan 13, 2015
5 Related Answers
the dr
joey shearer
  • 447 Answers
SOURCE: grinding noise when drum rotates
may be a foreign object trapped in between the inner and outer tub. Major Disassembly required to split the outer tub. May also be the rear bearing in which case back half will have to be replaced.
Posted on Oct 04, 2007
Anonymous
SOURCE: Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Posted on Feb 06, 2008
docjohn174
john gagnon
  • 943 Answers
SOURCE: drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
Mukesh Kumar
  • 3230 Answers
SOURCE: Dryer makes noise when turning like bearings going or belt squeek
check the following -
It's noisy
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley
Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel
Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
good luck.....
Posted on Mar 28, 2009
Anonymous
SOURCE: GE Washer Tub has sunk and is grinding on bottom
I had the same problem and as near as I can tell, we ran a load the was simply too big and the upper chasis "droooped" just enough from the weight to cause the metal to bow. As a result, the bottom of the tub assembly was rubbing against the lower metal chasis, creating a loud grinding noise. Metal filings indicated the wear point. I took a piece of wood that is about 1"x3x height and wedged it in front and slightly to the left of the motor, running straight, up and down. the board stands straight to take out the bowing- lifting the tub about 1/4" more. This was just enough to provide the clearance needed to prevent grinding. If the vertival board is too long, you won't be able to get the front cover back on.
Posted on Jul 26, 2009
My Hoover vhd 8142 washer wont turn. Some clothes got stuck in the doorway and when it spun it twisted everything up and pulled the seal off the door. We managed to get the seal back on. We put a load in...
Sounds Like the friction on the belt.If the drum got stuck the motor & belt keep turning plus the drum may of been pulled to an off set angle distorting the alinement's of the belt to the wheel that turns the drum.
Oct 01, 2017 | Hoover Washing Machines
J845 Samsung FrontLoader, no longer spins, makes a whirring sound, but nothing, just stopped; cleaned out everything according to the owner's manual.
if you are sure of whirring noise, then the motor is fine. check the drive belt that connects motor and drum
Mar 19, 2010 | Washing Machines
Changed everthing printer stll not working
You must be change drum unite,Its cleaning blade is weak,so it can not clean waste toner.
Dec 25, 2009 | Samsung CLP 300 Laser Printer
Smelly drum
clean the draw out and make sure the rubber door seal is clean if that is all clean then you need to do a cleaning cycle do the hottest wash with the normal detergent now the machine should smell nice hope this helps.
Aug 15, 2009 | Zanussi FS1055W Front Load Washer
I have konica 7130 i got my error in the screen f-26-3
F26-3 at power up.
Solution:
CAUSE: The toner supply unit (p/n 26WA-3200) is bound up preventing toner from being added to the developer unit.
SOLUTION: Replace the toner supply unit.
Jun 04, 2009 | Office Equipment & Supplies
Dryer has power but drum want turn
check to make sure that nothing is stuck in the blower wheel if nothing is caught then you need a new motor
Dec 19, 2008 | LG DLE2532W Electric Dryer
Nox faxing and black copies
make sure there is nothing stuck in paper path or the scanner lens is not dirty.
take out toner/drum tray and reinsert it to make sure nothing is preventing drum from turning or stuck.
then try to use
Jan 13, 2008 | Brother IntelliFax-2820 Laser Fax
PAPER JAMMED
You have a stuck sensor.
Open the rear door and make sure there is no paper in there.
Remove your toner from the drum and make sure there are no bits of paper stuck under the toner cartridge.
l
Look inside the drum chamber for the little plastic levers that actuate the sensors. Make sure they move back and fourth freely.
Dec 05, 2007 | Brother IntelliFAX 4100 Laser Fax
Leaking toner
Make absolutely sure you are using new OEM Sharp supplies for this machine. I sell OEM and generic, and I always have trouble with generics leaking in Sharp copiers. Also if the drum unit has toner backed up in the waste channel, it will leak out.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Apr 04, 2007 | Sharp AL 1631 Copier
Washing Machines Logo
250 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
