Question about Vehicle Parts & Accessories
Hi. I have a toyota Corolla 1995 model. It just dies out after idling for about 10-15 mins. When restarting, it will swing ang start but die out within a min or two. Help please!!
4A FE motor
Posted by mzamo myende on
ray012965
    Sergeant:
  • Vehicle Part... Expert
  • 444 Answers
This may sound like a possible dirty fuel filter or bad fuel pump check fuel pressure normally between 45 to 65 lbs another possibility would be throttle body may also be dirty a can of throttle body cleaner will clean it.if you have a check engine light have it scanned a faulty mass air flow sensor can cause this symptom.
Posted on Jan 13, 2015
  • mzamo myende Jan 13, 2015
    Thanks Ray, changed the fuel filter, the pump runs well. With sufficient pressure maybe something with the throttle or some sensor? Black smoke on the tailpipe and of cz idling s high at 1400rpm
1 Related Answer
madcox
Joita Constantin
  • 103 Answers
SOURCE: I got a 2002 Kawasaki prairie 400 when I get it
That is because the water is not a friend with electrics especially with coils, ignition coils and spark plugs. If water reaches the coils the engine will stop and it will run again when water is evaporating.
Posted on Oct 20, 2013
Ml350 dies restarts
Does the engine appear to be idling low. The throttle plate may need to be cleaned.
Mar 26, 2014 | 1995 Toyota T100 Xtracab
2003 TOYOTA COROLLA 1.6 STARTS AND DIE IMMEDIATELY AFTERWORDS
check the idle solenoid on the carby is connected or the idle sensor is ok
Jan 21, 2013 | 1995 Toyota Corolla
Its a 115000 btu multi fuel.it starts up,runs a few seconds,then shuts off.it doesnt smoke or anything wierd,it just shuts off.
It can be low fuel pressure issue or clogged fuel pump. Or its engine related issues,---------------
Check the help link mentioned below to troubleshoot the problem: ------
Engine stalls when gas is given?
http://technoanswers.blogspot.in/2012/01/engine-stalls-when-gas-is-given.html
Car stalls when MAF sensor is connected?
http://technoanswers.blogspot.in/2012/01/car-stalls-when-maf-sensor-is-connected.html
Car Engine Stalls While Driving?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-stalls-while-driving.html
Car stalls and throws white smoke from exhaust?
http://repairhelpcenter.blogspot.com/2012/01/car-stalls-and-throws-white-smoke-from.html
Stalls And Dies At Stop Sign?
http://www.howtobyme.blogspot.com/2012/07/stalls-and-dies-at-stop-sign.html
GMC Sonoma Stalls and idles low
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
Nissan Pathfinder stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
1992 Chevrolet stalls and shutdown?
http://schematicsdiagram.blogspot.in/2012/04/1992-chevrolet-stalls-and-shutdown.html
Stumbling and stalling at idle after engine rebuild?
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1990 mazda 323 stalls and quit running?
http://technoanswers.blogspot.in/2012/02/1990-mazda-323-stalls-and-quit-running.html
2000 Toyota Camry: Idling and Stalling Problem?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-idling-and-stalling.html
1995 Toyota Corolla: Stalls, Sputters and Pops Through Intake Manifold?
http://whatisbyme.blogspot.in/2012/05/1995-toyota-corolla-stalls-sputters-and.html
1999 Toyota Camry: Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
Dodge Dakota stalls, stumbles at idle. Has low fuel flow and runs hot?
http://schematicsdiagram.blogspot.in/2012/03/dodge-dakota-stallsstumbles-at-idlehas.html
1994 Toyota 4Runner: Stalls and Stops While Driving?
http://whatisbyme.blogspot.in/2012/05/1994-toyota-4runner-stalls-and-stops.html
1997 Toyota Camry: Erratic Idle and Intermittent engine stalling?
http://technoanswers.blogspot.in/2012/04/1997-toyota-camry-erratic-idle-and.html
Ford Maverick: No Idle and Stalling issues?
http://schematicsdiagram.blogspot.in/2012/04/ford-maverick-no-idle-and-stalling.html
These details will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
1998 corolla dies when idling runs ok driving
Engine stalls cold or RPM fluctuates at idle up and down or dies near idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control. If the above cleaning doesn't cure your issues you need to have the computer controlled automatic idle speed control system diagnosed and repaired by a dealer or electronic engine control repair shop.
Nov 06, 2012 | 1998 Toyota Corolla
Dying when first starting
try cleaning the idle air control valve
Sep 14, 2009 | 2001 Toyota Corolla
86 toyota corolla, dies at stoplights and idles rogh
well you could try to get a vacuum gauge and see if your car reads what it supposed to and if you buy one it could tell you what it could be.
May 20, 2009 | 1986 Toyota Corolla 2 Door
88 Toyota Corolla backfires through carburetor.
If that is carbureted, and has a mechanical fuel pump, try running a length of fuel line from inlet side of pump to a gas can that has fresh, clean fuel, and if it runs good that way, you know problem is most likely in the tank. Removing the tank & cleaning it out is best solution from there. I'd even be tempted to add a small bottle or 2 of Lucas Fuel Sytem Cleaner to first fill in clean tank, just to help clean lines as well as carb.
May 20, 2009 | 1994 Toyota Corolla
Car died
The steering is powered by the crank by a v-belt, so, this only works with the engine turned on. Check all the gas supply lines (and fuel pump) and the electrical power from the distributor.
Jul 10, 2008 | 1995 Toyota Corolla
Vehicle Parts & Accessories Logo
90 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
