SOURCE: When i connect my hp laptop to my panasonic plasma
Hi, you probably won't get audio from the HDMI port on a laptop post the exact model so I can check for you, you can get an adapter from the audio out to the in on the TV, as for the resolution, lower the resolution on the laptop before connecting it, simply right click the mouse anywhere on the desktop, then left click on properties then settings, then pull the resolution level to 800x600 save by clicking apply and OK , try a few settings to get the highest resolution the TV can display correctly.
Thanks
E
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: how to connect sound bar
Does your TV have an Audio out? If it does then you can connect it from there.
SOURCE: I have a 46 panasonic
SOURCE: Im trying to connect my
You will be needing a RCA Digital TV box converter or Digital RCA TV box converter. This converter will be the link between the Sound bar system and TV.
You should find this converter in any electronics accessories store within you vicinity or check walmart store close to you or order it online from walmart (But I don't recommend ordering online because of it's problem sometimes).
Check the back of the converter, it should have an input for Digital and RCA output and vise-a-vise.
Take a look at this Walmart link; http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
I hope you understand the above.
Good luck.
