A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Hi Graham
This should be fairly straight forward.
Your BT Home hub should be transmitting 2 signals. One called BTfon and another called something like BTHomeHub2-PGD3.
The second is what your computer should be connecting to to access the internet. If you look at the back of your home hub you will see 4 rows of numbers/text.
One should say SSID and have have the same ending as the transmitter that your computer should be seeing. Underneath that it should say WEP code or WPA. (or something similar) What follows is the password you need to enter to access that home hub's internet transmitter.
The BTfon thing is for the telephone that comes with some versions of the hub - it's not for the computer.
First, Can your 3GS connect on ant other Wi-Fi? If so the issue is specific to configuration on either iPhone or BT Home Hub. Second, Does BT Home Hub configured for any kind of mac-address security? Check that, if it does either remove it or add the iphone mac-address, you can find the iphone mac address under network setting. Third, Does Home Hub have limit on number of devices that can connect to it, some do. check that and make sure that you increase the limit or just remove the restriction altogether. Fourth, IS BT Home Hub Wep enabled? If so the password/key you are entring on your iPhone must be exactlythe same. Or just remove the wep encryption to see if your iphone 3GS can connect. Fifth, If your old 3G is able to connect to your BT Home Hub, then just make sure you are not FAT fingering the keys and entering a different key.
Try this link http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=27873&s_cid=con_FURL_gettingsetup/interference#tab4 I had the same problem. I tried everything I could think of but this is what eventually fixed my problem. Hope it works for you
Yes, you are able to connect your 360 using a hardwired connection. In fact, it is even faster that way!
Your BT Home Hub has two ethernet jacks on it, for use with whatever devices you wish to connect to the internet (in this case, your 360). Simply plug your 360's ethernet cable into the jack, and voila! You can now access Live. However, if you wish to host games over live, you may need to open up certain ports for Live to use.
The ports are listed at: http://support.microsoft.com/kb/908874
A manual for using and setting up your BT Home Hub is at: http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=16536 Near the bottom of the page is a link for the PDF version of the manual.
