Question about HP Office Equipment & Supplies
Remove fax card from hp printer 2400 - HP Office Equipment & Supplies
Posted by Lindsay waldrop on
ONE-Touch-Solution
  • HP Master
  • 1,679 Answers
You cannot remove the fax card from the printer. It is inbuilt. May i know the reason you want to remove it ?
Posted on Jan 13, 2015
How can I scan and fax 84 page document from the PIXMA mg7120?
that is correct, use the automatic feeder tray, but i am not sure if that machine can scan and fax all the 84 page continuously
Feb 12, 2015 | Canon PIXMA MG7120 Inkjet Multifunction...
How do I clear the paper jam from my hp c410a printer
Hi Anon
Please use this link to view the HP video on clearing paper jams.
http://www8.hp.com/h20621/video-gallery/us/en/customer-care/1483440795001/fixing-a-paper-jam---hp-photosmart-premium-fax-e-all-in-one-printer-c410a/video/
Sep 10, 2014 | HP Photosmart C410a Premium Fax Wireless...
Fax machine not working on HP LaserJet M2727 nf
> Incoming & out going both are not working?> Check line is OK?> Remove left side cover
> Replace Fax card,P.No CB534-60117> Replace Formatter PCA P.No.CC370-60001 > Most of the cases found Fax card failure. see the snap shot of fax card.
Oct 13, 2011 | HP Laserjet M2727nf Multifunction Printer
My Hp scanjet 2400 not working, always display error massage: scan still runing, or being using by another aplication. wait untill it completed
sir remove you any printer install in computer or something pending print on your printer remove it or canceled printer.
Feb 22, 2010 | HP ScanJet 2400 Flatbed Scanner
HP SCANJET 2400 ONLY SENDS ATTACHMENT AND NOT IMAGE TO FAX
It would be best to simply save the scan as a File, JPG, and then simply open it in say Word or the like. and use it that way. You can get software that actually turn you Scanner & Modem into a Fax machine.
Here is a link with a tutorial of how to set it all up..http://www.microsoft.com/windowsxp/using/setup/hwandprograms/printfaxscan.mspx
Feb 08, 2010 | HP ScanJet 2400 Flatbed Scanner
Hi my machine wont send or recieve a fax despite being properly connected. printing from computer is fine. has worked fine up until today
Hi check the following article to from HP
Problems with sending and receiving FAX
HP FAX ISSUES
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 05, 2010 | HP Photosmart 2610 All-In-One InkJet...
HP Scanjet 2400 scanning picture green and backgroud green
go to scanning software in ur computer change color section and remove this problem
regards
john
Nov 03, 2009 | HP ScanJet 2400 Flatbed Scanner
I need a memory card for my HP 2400 printer. Can I use any memory card??
try. any card that can fit. it won't ruin it. just dont push it in too far in case
Jan 08, 2009 | HP Photosmart 2410 All-In-One InkJet...
Hp officeject 7410 fax
Check to make sure all the phones attached to that phone number are on the hook.. sometimes an answering machine can create a problem also.. if you really want to check the printer / fax machine out, just remove all the phones that exist on that phone line and leave the fax machine connected. once all the phones have been removed and the 7410 is still acting up, you might have a bad fax card in the printer.
Mar 21, 2008 | HP OfficeJet 7410 All-In-One InkJet...
42 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
