I have error read out f28. What is the problem?
SOURCE: My Whirlpool Duet Front Load Washing Machine is
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
SOURCE: ERROR CODE F28
Unplug the machine at the mains. Remove the detergent tray. Reach all the way back with your hand in the slot where the detergent tray normally fits and feel for a lever. When you find it pull it forward. Then replace the detergent tray. Plug the machine back on and the error code will have reset and the machine will be useable again.
SOURCE: whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
SOURCE: have a whirlpool duet sport getting a f28 error
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&%#
SOURCE: whirlpool duet washer, error code f28
