Roy, change your cable, must be faulty and not giving a signal to TV.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
First, ensure your tv is using the highest resolution possible (Usually 1080 for flat screens) by using an HDMI cable from the receiver to the television, and that you are on the correct input. Second, ensure your tv is not sizing the video by using the 'picture size' or 'aspect' or 'ratio' key on the remote that came with your tv (Not your DISH remote). Third, tune your DISH receiver (with your DISH remote) to an HD channel (for VIP model receivers, when you tune the channel to an HD channel, an opaque white 'HD' appears insude the blue box at the top of the screen). Fourth, hit the star key on the remote, while watching the screen. On the right hand side, near the top, it will cycle as you hit repeatedly the star key, the style of screen widening. Hit the key as often as you need to make the screen appear the way you want it to. The receiver will remember your setting for all HD channels. When finished with the HD channel, tune your receiver (with your DISH remote) to a SD channel (any channel in the guide that does not have the HD icon). Repeat the fourth step.
For Hopper/Joey family receivers, hit menu, settings, screen size. Follow the instructions to resize your screen to match your preference. When finished, repeat step four above on each an HD and a SD channel.
Hi Jim, your nearly there, all you need to do is go into the tv menu and move from DTV to the old type channel numbers and then find the bit where you can manually tune the tv to channel 68.
Have a sky menu picture running and you will see it come in.
Try configuring your antenna input. Menu, Installation, Terrestrial, Input Config select your antenna 1 or 2 and > arrow over to select cable. Next auto program: under Terrestrial, Channel Program...this take some time.
both of those channels are in anolog, so on todays tvs they are going to look that way, sorry , something you have to live with if the cable company puts them on a digital channel they will look better but not HD quality
Have you contacted your satelite provider? Have you any other HD sources to try, A Playstation 3, a blue-ray disc player or even using the TV's terrestrial HD tuning system can tell you if its the TV or the Satelite.
press and hold select and red until the led blinks twice type in 0 0 6 0 press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
How are you hooked up? I.E. terrestrial, satellite, ?
If the channel on HD isn't strong enough to pull the signal, sound won't play because it isn't locked. Because you have sound on non hd it is a signal issue not the tv.
