Question about HTC T Mobile Mda Sda Smartphone Rapid Car Charger
My mda isnt turning on
I carged it for 3 days and it dosnt work i press the power button but it still dosnt work. how do i turn it on or get it to work? i have the battery and the sim card in but i still dosnt work.
Posted by eric2d2r14 on
Anonymous
  • 80 Answers
Please check your battery. it may be because of the battery may gone dead, else check with your battery,,, thank you,, plz rate me..
Posted on Jul 07, 2009
Help my laptop seems to have no power when turning on.....nothing happens...do I need a new battery or power plug???? Please help?? Need computer for school!!
hi generally most new laptop have a internal shut off if there is some kind of power surge, here is the solution to try it works on most laptops these days but dosnt get documented enough
1 Removed the battery and power cord from the laptop
2 Press and hold the power button on the laptop for 30-60 seconds ( the longer the better)
3 Connect the powercord to the laptop but leave the battery out
4 Try and power on your laptop - if it turns on you are good to go just reinsert you battery and repeat if it happens again
Aug 27, 2013 | Toshiba Computers & Internet
My laptop isnt powering on. a friend replaced the power plug inside, and now there is no power. Also what does the jumper/connector j4402 near the cmos battery connect to?
Aug 22, 2013 | Toshiba Satellite L675D-S7046 Laptop
Acer aspire 5520 5912
Aug 16, 2013 | Computers & Internet
AOC L26W861 LCD TV : 1. When TV is turned on using remote, it just recycles through all the pre-programmed channels 2. Unplugged the power chord several times but is still does the same 3. Power button on...
Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Nov 06, 2011 | AOC L26W861 26 in. LCD TV
Smashed my screen on my mda vario got a new phone now want to active sync in but cant remember my pssword is there a work around?
Yes, you need to perform a hard reset.
To perform a hard reset
1. Press and hold the Comm Manager button and Voice Command
button on the device. At the same time, use the stylus to lightly
press the RESET button.
T-Mobile MDA Vario hard reset soft reset hardreset softreset
2. Keep the Comm Manager button and Voice Command button
pressed, and the following message will appear on the screen:
3. Release the two buttons, and press the Send button to perform a
hard reset
Feb 05, 2011 | T-Mobile MDA Vario Smartphone
I cant get my mda to turn on i hold down the power button for a while but it wont turn on i charged it for 3 days and it still wont work what should i do?
Mda Vario's don't charge when turned off, heres what you do.
cut wire off a usb lead the small end strip the red and black wires, put the red wire onto the posative connection where the battery is it tells you what side is posative and negative on the battery, use black with negative and red with posative making sure that no wires touch the other metal strips in the phone, replace battery plug usb into computer and start up the mda and wait for it to boot. once turned on leave to charge as it will charge through the wires connected to the battery, after 10 to 15 minutes plug in the actuall charger and try to remove usb wires without taking battery out. if that is not possable it is ok as the battery should have enough power to start up once it starts leave to charge and always keep some charge in the phone.
Jul 07, 2009 | T-Mobile MDA
My T-Mobile MDA won't turn on or take a charge, battery was low
I had the same problem, but got the idea to "jump start" the battery from Googling the problem. At night, I had turned off my MDA to charge the battery and then in the morning, couldn't revive it. I removed the battery from my MDA, and determined which battery terminal was positive (far end of one side) and negative (far end of the other side) by using a multi-meter. BTW: Battery was still @ 3.5V (okay…battery was still alive, if just barely). Then, I found a 5V DC charger (5W Max output = ~1A) from my bluetooth headset. I used one wire (CAT5E) and connected it to the negative side of the adapter (outer sleeve - again, verified by multi-meter) and another wire to connect to the positive tip of the adapter. I had to strip about 1/2-inch of the insulation off of the wire on the DC adapter side, and about 1/8-inch of the wire on the battery side. Plugged in the 5V DC charger and then I touched the negative wire to the negative battery terminal and held it there, while I touched the positive wire to the positive battery terminal for about 30-45 seconds. Put the battery back in the MDA, started it up, and now it's charging on the regular MDA AC Charger that came with the phone. Problem solved.
I’m happy to assist further over the phone at https://www.6ya.com/expert/daren_80e8def41854e57e
Apr 07, 2009 | T-Mobile MDA
UNCOMPLETED MDA UPDATE
this is a sw boot up screen. this is what the screen will look like with no sw on the device, so you guessed it....the download was unsuccessful and corrupted the firmware.....if you tried to reinstall the sw again, and it does not work, you might need a new phone....contact t-mobile to do that.....OR, you can try to do a master reset by pressing the sw keys.
to do that, turn off the phone, and press and hold the soft keys (buttons located beneath the touch screen that have the lines on them on top of the green call button and the red end call button).....while holding these down, press the power button for 3 seconds and release the power button.....all this time you are holding those soft keys down....the phone SHOULD turn on and go to a black screen with white writing.....at this time you can relase the two buttons......press the green button and reset. if this does not work.....my friend, you need another one......good luck!
Dec 16, 2007 | T-Mobile MDA
MDA sound problem
1. plug in handsfree
2. pull handsfree ^up^ (holding it hard), and at the same time
3. slowly pull out
Oct 12, 2007 | T-Mobile MDA
Mda
throw the phone battery into a zip lock bag and put it in the freezer for about 12 hours...then put it back in the phone...should work just fine! same thing happened to me
Aug 31, 2007 | T-Mobile MDA
HTC T Mobile Mda Sda Smartphone Rapid Car Charger Logo
83 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
Caltronic TV Repair
Caltronic TV Repair
Level 1 Expert
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
