Question about Whirlpool WTW5550XW Energy Star Qualified Cabrio High- Efficiency Top
New lid switch
SOURCE: how to replace lid switch assembly #3949247 for a Whirlpool Washe
we just bypass them,unless your going to stick your hand in there during spin cycle,-unplug washer,remove the 2 head screws 1 on each side of the head,flip the head up,you will see the lid switch jack in the middle of the top of washer, unplug it,cut the 2 outside wires and wire nut them together,plug back in,put the head back,plug in washer and your done,this way it cost you nothing to fix,the other way would be around $40,let me know how you do-mike
Posted on Apr 20, 2009
SOURCE: Installing a whirlpool cabrio washer lid switch.
See the following Whirlpool Service Manual for the Cabrio.
This should help.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Posted on Nov 10, 2009
SOURCE: The lid will not lock on my Whirlpool Cabrio
id change the door switch
Posted on Feb 06, 2010
SOURCE: Whirlpool Cabrio WTW6600SBT Top Load Washer won't aggitate
My Whirlpool WTW6600 had the same problem. The tub no longer floated up and down on the center shaft, so it only spun, not agitated. You must remove the tub (with some effort) and lightly sand / clean the center shaft. Lube it lightly with wheel bearing grease so that after it is reassembled, you can pull the tub upward and feel about 1/2" movement. This will enable the proper gear assembly to engage. It can spin when it rests at the bottom of its travel, but once you fill the tub, it floats, moving upward, and engaging the agitation gear. Good Luck!
Posted on Dec 24, 2011
SOURCE: lid lock won't release on Cabrio washer
hey there have you tryed un plugging it the pluggin it back in
Posted on Nov 18, 2012
Oct 03, 2016 | Whirlpool Washing Machines
Oct 12, 2015 | Washing Machines
Jan 12, 2015 | Whirlpool Washing Machines
Jan 12, 2015 | Whirlpool WTW6400SW Cabrio Washer
Dec 14, 2014 | Whirlpool Washing Machines
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Feb 11, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
May 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Nov 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Jan 22, 2018 | Whirlpool WTW5550XW Energy Star Qualified...
222 people viewed this question
