I disconnected the power for about 10 min.then reconnected it back, set the right clock back. the restarted the self cleaning cycle again, when all was clear, the door will not open again. I tried lifting the glass top to reach the inside, it will not move.
Thank you for your inquiry, Sam Aghajan!
I see that your Frigidaire range has went through a self-cleaning and the door will not open. It sounds like a possible issue with the door latch or control panel. I understand that you have reset your range and performed a second self-clean. I would suggest holding down the cancel/clear button for five to ten seconds. This should help to unlatch the door. You can also perform a self-clean cycle and before the cycle starts clear it out and that should help to release the door. If that does not work I would recommend contacting a professional technician to come out and repair the latch. Good luck. -Matt
Good Afternoon friend, thanks for your inquiry!
To locate instructions regarding self-clean on your Frigidaire range I would need to have your model number. I have provided a link for you to use once you have your model number to locate any Use and Care Guides available on your current appliance. I hope this helps to some degree and if you need assistance please reach back out. -Matt
