Question about Behringer Europower Pmp5000 Powered Mixer Pmp5000
I have a Behringer europower PMP6000 powered mixer. when I power it up the LED lights flash and the built in effects do not power up.This mixer is over 3 years old so taking it to a repair shop is not
Inspected the boards and components for visable signs and found nothing wrong that I could see. I use this board at church and there was a power spike then it started doing this.
Posted by J McAlister on
5 Related Answers
Fred Yearian
  • 5603 Answers
SOURCE: my effects on the behringer djx 700 dj mixer stop working how
This is a wild educated guess.
I repaired a Behringer guitar amp that had a DSP effects in it (BX1200 I believe).
The effects were on a seperate board and the board had its own 5 volt power supply. The filter capacitor for the 5 volt power on the board was UNDERSIZED and it had degraded causing the 5 volts to drop out of regulation, dipping to 4 volts. This caused the DSP effects to fail.
YOUR device MAY use the same DSP OR design.
Check the 5 volt power with an OSCILLOSCOPE to look for dips below the 5 volt operating point that occur at 120 HZ.
Posted on Oct 24, 2009
hmerchant110
AliTech110
  • 7191 Answers
SOURCE: I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Posted on Jan 15, 2010
Fred Yearian
  • 5603 Answers
SOURCE: Behringer XENYX 1622FX, won't power on. Phantom power works(?)
After reviewing the schematic, I don't understand how the Phantom power can REMAIN on with the power switch off... this CANNOT occur except for what energy is left in the 48 volt supply filter cap... This might last for minutes after the fuse went... UNLESS you have devices connected which are backfeeding the 48 volts. (which would be a disaster)
The 48 volts, +/- 12 volts and +/- 15 volts and the +5 volts ALL come from the SAME switching power supply. I suspect one of the filter caps went or the primary switching regulator a TDP245Y chip.
You should ONLY work on the line side of this using an ISOLATION transformer since the line side has lethal voltages.
To do testing, one replaces the fuse and puts a 60 Watt light bulb in series with the hot side of the inout line. The lamp "acts" as a resetable fuse and limits the current for testing. When all is well again, the lamp will remain out with the power flowing through it.
The D1 diode bridge and C7 input rectifier and filter are first things to check. You can do those with an ohmmeter.
I will caution you to ALWAYS power any and all equipment from the SAME power source. Plugging in devices from across the room will set up ground loops and any ground fault will fry equipment.
Posted on Apr 05, 2010
sparky1500
Matthew Spark
  • 1066 Answers
SOURCE: i just both the Europower pmp6000 powerd mixer and
use 1/4 inch speaker cables. hook one speaker up to "main 1 R" out and the other to "main 1 L" out. if you have additional main speakers, hook them up the the "main 2" outputs.
look for the "bridge amp mode" switch and move it to the "main L- main R" position.
Posted on Nov 06, 2010
Fred Yearian
  • 5603 Answers
SOURCE: Hello! I have a
Often teh power supply fails because of other problems. Unless the board has flame damage the parts that are defective can be replaced... Getting some of the parts that are special can take time. Most of the components are available at many sources however. The SPS400 power supply can be repaired.
Here is link to schematic that should have the SPS400 as well as the rest of the PMH1000 on it.
http://elektrotanya.com/behringer_pmh1000.pdf/download.html
Posted on Jan 18, 2011
How to wire up outboard effects, poweramps to mixer. Out to sub, mains, monitors each with own poweramp, and several outboard effects, eq's, comp/lim/gate, sonic maximizer, quadraverb, crossover.
I'd need to know what mixer you have, to know if there is a [line out] connection socket and an [internal amp in] connection socket.
"each with own poweramp" I presume means the ep1500's and NOT that the speakers are active (ie containing amps)
***If any of your speakers are active, ask the question again, with more detail.***
So if all your speakers are passive, I offer the following.
I assume there is [effect send] and [effect return] on the mixer
effect send>quadraverb>effect return
mixer line out > eq > compressor > sonic maximizer > crossover
sub output of crossover> amp > sub
high output of crossover to mixer's internal amp input
mixer's speaker output > main speakers
monitor output > other side of eq (>other side of compressor if desired, but use sparingly ) > other side of sonic max if it is true stereo , otherwise skip > amp > monitors
If your mixer doesn't have an input to its internal amp, we are "back to the drawing board"
With questions like this it pays to give as much detail as possible; model and make of each component etc
I have done my best with the the info you have provided.
Don't feed amp outputs into powered speakers
Oct 18, 2017 | Behringer Europower Pmp5000 Powered Mixer...
.necesito un diagrama esquematico para europower MPX 5000
.necesito un diagrama esquematico para europower pmp5000 pmp6000
Jun 29, 2012 | Behringer Europower Pmp5000 Powered Mixer...
We have a pmp6000 mixer hooked up to our ep 4000 and b1800 and b2520,it seems we can only hook up the amp to the mixer into either mono's 1 and 2 or the main 2 however not in main 1 with full...
MAKE SURE the cables you plug into 1/4 inch mains are TRS plugs, and not mono cables (TS). The main output 1/4 inch jacks are TRS balanced outputs and if you plug mono (TS) cables that shorts out the ring connector reducing the power by 6 Db. USE ONLY TRS balanced cables for interconnects !!!! Also read my tip on Fixya regarding PMP mixers. If you use 1/4 inch SPEAKER cables or adapters, if you short the SLEEVE of channel A output to ground you can pop the channel A amp. The TIP of channel B is the hot BUT the SLEEVE of channel A is the HOT. The ttip I posted explains why this is and it isn't mention in the Behringer documentation.
Aug 06, 2011 | Behringer EUROPOWER EP4000 4,000-Watt...
Behringer europower pmp1000, mixer unit, has all leds lit ,is responding to mic. input, bur is not producing any ourput to speakers, can you advise please.
ALL LED's should NOT be lit all the time. If thsy are, there is a failure in the power supply.
plug headphones into the 1/4 inch main output jacks on the top... you will only hear sound in the left side headphone for each. This would verify the preamp is working.
Jun 25, 2011 | Behringer Europower Pmp1000 Powered Mixer...
Need part # for the Program Push Button Control for the effects on a PMX2000 power mixer
You will have to call Behringer in Woodinville WA to get the Behringer part number. Their phone is:
(425) 939-3200
With the number plus an incident number that Behringer will give you, you then call FullCompass who is the parts distributor... Then, unless they have it in stock, plan to wait a long time to get the part. FullCompass phone:
800-356-5844
Lots of luck... I have waited for three months for parts.
Apr 07, 2011 | Behringer Europower Pmp5000 Powered Mixer...
What is the bridge amp setting mean on the pmp6000?
In bridged mode, both sides are used to drive the same speaker. One side is phase inverted relative to the other so the two sides add their voltage. It is important to note that you cannot go below 8 ohm speaker in this mode. The amps can generate about 60volts peak or about 43 volts RMS. So the net will be about 86 volts between the two sides. With 86 volts on 8 ohms you can get about 925 Watts max... yeah it is not the claimed 1200, but it is a lot closer than the shop vacuums claiming 4Hp when running on 120 volts... Those are peak values that have LITTLE to do with actual true values.
You can't run stereo in this mode because BOTH sides are used as a single power source. The PAN controls will have little effect as the system is in monaural mode.
Mar 18, 2011 | Behringer Europower Pmp5000 Powered Mixer...
None of the channels work. Most of the LED lights work. Im going thru the beringer mixer for power but using another mixer.
If you plug into the PA input or inserts of this unit, that DISCONNECTS all the mixing channels within this unit and none in this unit will work. That is how it is supposed to work.
If you wish to use another mixer as well as the channels in this, I suggest you run the other mixer into one of the stereo channel inputs OR the CD inputs, although the CD are NOT balanced inouts and subject to higher noise level.
Feb 01, 2011 | Behringer Europower Pmp5000 Powered Mixer...
My pmp6000 wont work in mon1/ mono mode. I have one speskon channel going to two mains and the other to two monitors Can't get sound.
OK... from the schematics it appears that when in mon1/mono mode you use ONLY the MON1 gain controls, including the channel MON1's and the MON1 slider. Make sure you have each of those turned up as needed. In this mode, MON2,s and the MON2 slider are unused. The MONO slider controls the MAIN output.
Dec 03, 2010 | Behringer Europower Pmp5000 Powered Mixer...
I just both the Europower pmp6000 powerd mixer and Eurolive b215xl speakers and i need help conecting the speaker to the mixer. I will be using it with some mics at a function in an hotel. How do I connect...
Nov 06, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Behringer Europower Pmp5000 Powered Mixer Pmp5000 Logo
573 people viewed this question
Top Behringer Music Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Behringer Music Expert? Answer questions, earn points and help others
