Whirlpool 22" Dual Zone 38 Bottle Wine Cellar Chiller Cooler WWC287BLS Logo
J
Julianne Posted on Jan 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bottom level of wine cooler frosted up. Trying to defrost. What is the problem?
Defrosting it
Gil Shultz
Level 3:
  • Whirlpool Master 3,464 Answers
  • Posted on Jan 12, 2015
Gil Shultz
Whirlpool Master
Level 3:
Answers
3464
Questions
Helped
731733
Points
11104
It sounds like your thermostat is set to low, if there is a fan check it. That can also happen for a while before it quits working if there is a refrigrent leak.
I have frost on back of unit.what to do?
Usually if you see frost or ice it is because the Freon level is low. There is a 5 year warranty on the compressor and sealed cooling system so if your within that period, I would call the manufacturer.
GE Profile refriderator PSC25MSWA is frosting/icing on bottom of Refriderator side
Try defrosting entire unit. Put all food, freezer and refrigerator sides in coolers with ice. Unplug unit and wait at least 24 hours for unit to completely defrost, if neccessary open doors, plug unit back in and see how unit functions. By doing this lines that carry freon should become unclogged.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
2answers
I have a GE ZDB24A under counter wine cooler that continues to frost up regardless of the setting. I have a second cooler downstairs which stays clean - no frost. What do I need to do?
check the door seal, make sure that its not ripped or dirty. Its possible that moisture is entering the wine cooler thru the door gasket. Frost is normally the result of warm moisture mixing with cold air. The door gasket should be the problem. if you thoroughly examine and its fine, let me know and we'll go to the next step.
1helpful
Interior icing of back wall of wine cooler, Sears (Kenmore) model 461.99609, stand alone wine cooler
as this is not self defrosting you have to do it yourself..........warm air causes frost buildup!
I was defrosting my fridge and punctured the tube
might be possible, depending where exactly the puncture is, but if it was repaired it would need
regassing to the correct level, you would need a professional refrigeration engineer,
My Frigidaire freestanding wine cooler only seems to cool as low as 53 degrees when I have it set to its minimum temp. The manual says the minimum temp should be 40. Is something wrong with the unit?
YES! Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush
Fridge is warm and freezer is cooler than normal
Possible bad defrost timer. Locate timer underneath the fridge and manually turn the knob. Element should come on and start defrosting. If defrosting starts then the timer is bad. Check also the element and thermostat.
Frost is building in wine cooler
Check the door seals to make sure they are sealing good this can cause high humidity. The unit also seems to be getting to cold check with another thermometer
Top Whirlpool Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Furniture Expert? Answer questions, earn points and help others
