Question about Jacuzzi Home
TIGHTEN JET LEAKING - Jacuzzi Home
Posted by STEVE ALLABAND on
Gil Shultz
  • 3,388 Answers
Check, it sounds like it is cracked.
Posted on Jan 12, 2015
Gas leaking from carburetor bowl drain screw when pushing in primer. Push primer two times and couple drops of gas on floor. Any way to tighten spring screw on carburetor bowl?
Sounds like you need a gasket on that screw. Don't over tighten as you could mess up the threads. I think this is the screw that has the
fuel jet in it. If you take it out its good to clean out that jet as well to have a good running machine.
Jan 05, 2014 | Mtd Snowthrower 208cc 26"
Will not idle and bogy off the line
Instructions
    • 1 Turn the gas valve between the gas tank and the carburetor to the off position. Place the drain container under the nut on the bottom of the carburetor.
    • 2 Remove the nut on the bottom of the carburetor with the pliers. Drain the gas into the container and then replace and tighten the nut.
    • 3 Remove the stock jets from the right and left side of the carburetor with the screwdriver. The jets are the gold pins that are in clear view.
    • 4 Insert the new jet pins into the jet holes according to the instructions in the jet package. Tighten the jets according to the jet chart in the rear of the owner's manual.
Jan 20, 2013 | Honda CR 125 R Motorcycles
Leaking jacuzzi jet
The workings of a bath jet...From the inside of the Bath there is a wall fitting that threads from the inside of the tub into the jet body located on the outside wall of the tub.
If the jet is leaking at this point behind the tub then you should take the wall fitting out of the tub and put a small bead of 100% RTV silicone around the flange of the wall fitting and reinstall it.
If however, the leak is from the PVC piping going into the jet then you will need to replace the jet.
Rod
US Parts Center
888-521-6183
Jan 14, 2013 | Kohler Home
I have a stock #414457 Jet bandsaw and when I try to tighten up the vise, it jumps back before it's tight. I think the problem is with the
If you need parts for your band saw, you can visit www.bandsawparts.com . They offer cheap aftermarket parts of Jet band saws.
Nov 08, 2012 | Jet 414459 HVBS - 7MW Horizontal/Vertical...
I have a GE Select Top loading wash machine that is making alot of noise during the spin cycle. 99/2000 model
If it sounds like a jet plane taking off, a grinding noise, it is the bearing. This is pretty difficult to replace. If you do attempt it, you MUST replace the inner tub seal. This is leaking onto the bearing, causing it to go bad.
Jan 18, 2010 | GE WBSR3140DW Top Load Washer
I have a leaking jet in a pearl jet tub. it's an older model with just two jets installed in 1997 the jet leaks and i don't know how to jet the face plate off the jet, or have a diagram as to get the jet...
If there is a  threaded nut on the back of the jet, undo the nut as much as possible and push the jet out into the tub. Spread aquarium grade silicone around the jet and push back into the hole, put more silicone in front of the nut, you may have to spread it in the small area with your finger or if you can squirt it in from the tube of silicone. If there is no  threaded ring on the backside of the jet, go to the jet in the tub and looking down on the jet, turn it to the right. It should pop and pull out of the housing. There will be a retaining ring that may require a special tool to remove it, once the ring is out, clean it very well, spread silicon on the threads and the lip. Reinstall in the hole, reinstall jet wait 24 hours and fill and test for leaks. Take you time and you will not have to do it over again. Check where the leak is coming from, sometimes there is a hairline crack in the jet assembly, if this is the case, make sure the area is dry then use a 2 part epoxy for plastic (from lowes or home depot) and smear this all over and around the crack, let dry 24 hours, fill and test.
Sep 28, 2009 | Whirlpool Pearl Ballade True Bathtub with...
All 6 top burners have leaking compression flex connector fittings to jet burners. Need serviceman in San Francisco.
Youcan try tightening them up yourself. Need two adjustable wrenches, one to hold the connector to the burner and the other to tighten the compression fitting. After that have a solution of water and soap and spray all around your fittings to see if its still leaking, you will see bubbles, If its still leaking you will have to turn yourgas supply valve off and disconnect flex gas lines replace with new ones. After replacing do the same thing spray with the solution to see if they leak.If you dontfeel comfortable doing this dont.
Aug 25, 2009 | Wolf Range 18 in. SPR-100 Gas Cooktop
Leaks from jets along outer wall
This is a hard fix, The jets are glued on to the back of the tub with an epoxy type material. the jets should spin on and off from the inside of the tub. You need to determine if it is the hole where the jet is that's leaking or if it is the jet assembly and tubing that is leaking. If it is the jet hole that is leaking, spin the jet off and use aquarium grade silicone (Lowes carries it)
spread this around the piece sticking thru the tub and spin the jet back on. This is a hit or miss fix. No easy fix if it is the tubes or jet assembly, full access necessary for this repair.
Apr 24, 2009 | Home
Jacuzzi Leaking
you need to pull the jet body out and then put some 100% RTV silicone around the jet body and the inside of the wall fitting. Once the silicone is in place re-assemble the jet. that will solve the leak unless there is a broken piece on the jet body or the lip of the wall fitting.
Dec 09, 2008 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Home Logo
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
