Goes through cycles of washing clothes but fails to spin or turn
SOURCE: Kenmore frontload washing machine doesn't spin
If your washer won't spin, check these:
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
It spins only with the lid closed
For
safety, washing machines are made so that they spin only with the lid
closed. The lid switch prevents the spinning action when the lid is up.
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
SOURCE: frigidaire washing machine no spin cycle
I had the same problem with my Frigidaire Affinity front load washer. It would go through the wash cycle but would not do the final spin cycle that takes the access water out of the clothes. It would actually cut off when it got to be 6 minutes left. I checked the hoses, belt, motor and pump but all were functioning properly. I even cleaned out the filter thats located in front of the water pump. It was full of coins and other debris but it still didnt fix the problem. I called the repairman and he concluded that the control board was bad and would have to be relaced. The board is $200 and labor $140. It will cost you $340 dollars to correct this problem unless you know how to replace the control board yourself. Only had the washer for 3 years. I wouldnt expect something like that to occur within that short period of time.
SOURCE: My Frigidaire Model fails to spin after wash
my washer had same problems, turned out to be door lock switch. around $75.00. Washer 2 years old. Questioning quality also.
SOURCE: my zanussi washing machine keeps
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating and positive testimonial is appreciated for answering your FREE question
Testimonial: "Thank you! I drained the water from the filter and found some coins and hairball. Rinse and spin are now working and hopefully will continue to do so."
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
