Changed both (correct) black cartridges, gone through cleaning procedure - (twice). Also printed off test strip. Result - No black line at top,colors OK, but black bars shows down the left side if the colors.
SOURCE: many lines on photos despite numerous cleaning, deep cleaning
it could be a faulty printer head in the printer or purged unit not work correctly to clean the heads. you need to do a deep head clean then try printer head tested again. may need to do this a couple of time. still have problems get a new printer head for the printer.
SOURCE: Canon MX300 printer--I replaced the
Try this method to get the ink flowing:
If it is a compatible cartridge you have used then it is possible to get a failure. Most are re-manufactured and are not 100% Reliable.
Also make sure the contacts on the inside of the printer are clean and all there. sometimes they can be damaged by removing and replacing cartridges. these can be cleaned with alcohol wipes.
I hope this helps
Regards
GM
