Air Tools & Compressors Logo
Question about Chicago Pneumatic Air Tools & Compressors
How do I remove pneumatic staples from furniture.
Hammering staples from the back, they bend but they don't back out. I can't pry them out because they are too deep. I am using a narrow crown stapler.
Posted by Jo Gamma on
Den Teeters
    New Friend:
  • 3 Answers
Try a large pair of pliers.
straighten the staples as much as you can, grip one leg with the pliers about 1/8" from the wood, and tap the pliers with a mallet or wood block.
alternate "till you can grip the crown.
Posted on Jan 22, 2015
My One Touch stapler isn't stapling correctly. The staples go in but don't bend around in the back to secure the papers together. Is there a way to open up the stapler, other than inserting staples?
I don't think taking it apart will help - when staples don't bend behind the papers, assuming the correct staples are used, it is usually either the anvil is worn or there is some misalignment between the staple and the anvil.
The anvil is usually the part that wears out first, fortunately many office staplers use a dual anvil that can be turned around to select the staples being bent outwards. This position is ideal when the staple will need to be removed at a later date.
Staples are usually produced with a sharp square end to each leg that after a few thousand staples will have done some damage to the anvil or a few hundred if the anvil had slipped through unhardened.
I suggest you take a look under strong light and magnification and compare it with that of a working stapler...
tip
Power nail/staple gun
The worst pneumatic nail/staple gun is still better than the best electric nail/staple gun.
My Arrow PT50 air staple gun will fire one staple but the piston will not retract and I have to manually push it back for the next staple how do i repair, failure new not used very often
Either the piston needs lubricating, or the spring that returns it is broken. Most pneumatic tools do require "pneumatic oil" run into the air line before use.
.CENTRAL PNEUMATIC staples go right through insulation paper how to adjust
That’s the wrong pneumatic stapler that one is for nailing trim
How to replace the spring in the staple loader
Call the manufacturer with your email address and request step by step instructions on replacing the pusher and spring in your specific model number.
Surebonder 9600
Call the manufacturer with your email address and ask for detailed instructions on how to replace the pusher and spring on your specific model number.
These are instructions on replacing the spring and pusher for Pneumatic model #'s: 9600, 9610, 9615.
1. Wearing protective eyewear, remove air line supply HOSE from your gun, turn gun upside down holding the front of the gun in your left hand
2. Remove u-shaped piece that holds the track in place at the back of the bottom of the gun.
3. Slide track out of gun.
4. Take the long black spring (part # 38) and hook one side of it to the hook inside the pulled out track.
5. Feed the other side of the spring under the silver wheel in the front of the track and pull it up holding the tension. You might need to use the end of a paperclip to feed the spring through.
6. Take the u-shaped pusher (part # 33) and place the other end of the springs hoop onto the hook inside part #33. Make sure the opening of the hook faces the back of the track, and that you see the yellow tape so that it will show in your view window.
7. Carefully place part #33 with the spring attached and the opening of the hook facing the back of the track, back onto the front of the track. The springs tension will hold it in place.
8. Carefully slide the track back into the bottom of the gun making sure you are placing each side of the track into the grooves.
9. Carefully snap the u-shaped lock back onto the bottom of the track to hold the track in place.
10. With the tool upside down, slide your track open and be sure to place your staples in the bottom of the gun itself with the points of the staples pointing up towards the ceiling, not on the track.
Parts are available online at www.surebonder.com on the left hand column, select Pneumatic Parts, then select your tool. It will bring you to the ordering page.
1helpful
I have an older Fasco stapler, it is orange in color. S3G 16 is number on it. The part that pushes out the staple has a piece of staple stuck in it. How can I get this out?
Some models have small screws on the face plate that can be unscrewed to release pressure or a spring clip to release. You can also push the plunger back into stapler with a thin narrow srewdriver, the staple may fall out.
Remove a jam staple from a hardwood floor stapler
on that model there should be a few bolts on the tip side of the nose , remove screws and top part of nose and remove the damaged staple,, then replace parts
I have a PowerFast staple gun #31600. Can not
I got some staples stuck in my Powerfast 31600 too. I THOUGHT they were the right staples, I was wrong. You have to bend a little tab on the bottom of the stapler to let the slide come out of the back. Then you can remove the staples. Replace the slide and tap the tab back into place with a punch.
Open Questions:
Top Chicago Pneumatic Air Tools & Compressors Experts
David Shaub
Marvin
Marvin
Lawrence Oravetz
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
