Sometimes if you turn the car off it will let you adjust it but not every time.
SOURCE: Pioneer DEH-1100
Dont connect wires together randomly or you WILL damage the head unit. You need to get a multimeter. It will show you which wires have voltage and which wires are connected to speakers. I've found that old Pioneers have the same colour codes as new ones. So:- Black Chassis and negative. Red ACCessory switch (key) Yellow Constant 12v Orange Lighting Blue/white Auto antenna relay White Front left + White/black Front left - Gray Front right+ Gray/black Front right- Green Rear left + Green/black Rear left - Violet Rear right + Violet/black Rear right -
SOURCE: how do i turn aux on my pioneer deh-7600mp radio
Shut it off then hold the function button, cycle through till you find your option to turn it on, the turn the radio back on and use you source button to change to CD, TUNER, and AUX
SOURCE: pioneer deh-2800 50x4 how can
1) Press "source" and hold it until the unit turns off.
2) Press "audio" hold until clock appears in the display.
3) Use teh < and > to select the hour and minutes.
4) use ^ and v keys to change time.
SOURCE: The pioneer deh-1100 does not have a color code
Here is the breakdown of what wire does what:
+Red..............12v ignition
+Yellow...........12v battery
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Testimonial: "Thanx what i needed!"
