Question about Electrolux Ovens
Hi Electrolux cooker 607601 error code 4 f on the top oven when using the grill what does that error code mean. Kind regards
We haven't all we got to go on is the error code f4
Posted by Neil burridge on
Dado
    Master:
  • Electrolux Master
  • 509 Answers
It is good practice to specify model of appliance
(like EOG9330XN).
Probably means temperature range of oven sensor exceeded
(for more than 5 seconds).
Dado
Posted on Jan 10, 2015
F4 code is displayed and oven beeps continuously
Hello Duane, I am happy to assist you. Typically, error code F4 indicates a lockout error. Try resetting the unit by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC (electronic oven control) or the Lockout Control Board on the appliance will need replacing.
Aug 16, 2013 | Frigidaire 27 in. Electric Double...
Service Code F-3
The error code's F3&F4 are codes that mean their is a problem with the oven tempature sensor and that sensor is uncappable of telling the control board what the temp. is in the oven. This is what the sensor looks like,oldtech2332_20.jpgTo check the sensor,unplug it and place meter leads into the white plastic plug at the end and check for between 1060-1100 ohms of resistiance when its good.
The F3 error code means that the sensor is shorted so if it indeed is shorted the meter reading will show ZERO ohms resistiance instead of the 1060-1100 of a good one.
The F4 error code is for sensor that has a open circuit,so instead of the 1060-1100 of a good it the display on the meter will show infinate resistiance ( the meter display will not change)
If on either the F3/F4 error code if at room tempature when checking the oven sensor if the display shows anything other that 1060-1100 ohms the sensor is going to be the problem and needs to be replaced.
Nov 30, 2011 | Magic Chef Ovens
My oven displayed F5 then F3 code I believe after a nearby lightning strike, When installing new sensor with supplied wire nuts I found black marks on oven side connector. Immediate F4 error code when...
When checking the sensor it shouls be checked at room temp (even if power off) at it should be between 1060-1100 ohms at room tempature. 16 ohms the new sensor is shorted the F2/F3/F4 all relate a faided sensor and the F5 error code says the clock (electronic oven control) is defective.
Test the sensor again at room temp...if only 16ohms its no good and will throw the F4 code everytime again a good sensor measured at room temp should be between 1060-1100 ohms
GENE
Sep 06, 2011 | GE JTP15 Electric Single Oven
Error F4
Hello there:
whenever you get this error code F4 or even the f3 error code this is telling you that the ovens temperature sensor/probe is faulty and is unable to sense the temperature of the oven correctly.
So the fix for this is to get a new sensor OK SO IF YOU WILL GIVE ME THE MAKE AND MODEL # OF YOUR OVEN I CAN SEND YOU SOME PART INFORMATION ON THIS OK?
best regards mike
Jan 11, 2011 | Ovens
Oven wont light gaves F4
Hi, the F4 error code means Open or shorted oven temperature sensor (RTD)..
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Oct 20, 2010 | GE 30 In Freestanding Gas Range ...
F4 code Dacor oven
F4 means there is an open circuit in the Oven Temperature Sensor. Could be a bad sensor that needs replacing, cound be an issue with the wiring harness.
A test would be to short the sensor wire together at the sensor. the error code should change to F3. then you would know it is the sensor and not the harness.
Mar 03, 2010 | Ovens
F4 error message
HI. This is a failed oven temperature sensor error code. Simply replace the temp sensor, asap. This will clear the code. The temp sensors are generally located inside the oven, mounted on the back wall, in the top left or right corner.
It will look like a 4 inch slim probe.
F4 failed temp sensor.
Dec 29, 2009 | Jenn-Air JJW8230D Electric Double Oven
Older Ge F4 error Code
Your oven temperature sensor is bad and must be replaced.
Feb 28, 2009 | GE JTP85 Electric Double Oven
F4 error code on Jenn-Air W30400BC expressions built in oven
Slone, F4 is the code for a shorted temperature sensor. This is the temp probe in the oven. There are 2-quarter inch screws holding it on. It should pull out through the insulation until the quick connect comes through. If you want to make sure, the sensor should ohm out at 1143 ohms at 100 degrees. I think you can be pretty sure that this is the problem. The part number I have is 704657. Catriver.
Dec 04, 2007 | Jenn-Air JJW8527C Expressions Collection...
Ovens Logo
140 people viewed this question
Top Electrolux Ovens Experts
John Tripp
John Tripp
jdthefixer
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
